Bubbling Paint Issues Round 3
Carolina Jeeper
Rollie
North Carolina
So for three years in a row I've had these bubbles in the paint near the door hinges repaired. Also has the same exact problem on the leading edge of the hood and both passenger door edges.
This week I inspected these same areas and find the same issues again near 4 door hinges and the clearcoat peeling off of the hood that was repainted. There seems to be no stopping or resolution to this paint issue.
I know I have plenty of company with this, but just wondering what your thoughts are on this since this is my 3rd time.
JasonInDLH
Jason
MN
21 JLUR, 15 Yukon Denali
I’d Rather Talk Jeep’s!
I reckon you need to pull all the hinges off, remove all corrosion, and seal the underside of the hinge and part of the body where the hinge came off. The factory attaches the hinges first and then paints it. And if I’m not mistaken, the hinges are a different metal than the body.
I wonder if (after cleaning the metal thoroughly) you applied quality silicone caulk to the exposed metal underside of the hinge if that would stop this problem. That’s what I plan to do sometime down the road anyhow.
JasonInDLH
Jason
MN
By the way…your name, “Carolina Jeeper” reminds me of the time I got a bottle of Carolina Reaper hot sauce. Whew…that sure was hot. ?
Rico1111
Rico
RI
2018 Rubicon 2 door JL
yup Jasons right! I intend to do the same when it gets bad enough, mine have slight bubbling and I have not had it resprayed for the exact reason that it will come back(FCA is totally at a loss in how to remedy this) without seperating the issue of two dissimilar metals. I plan on using a primer to lock down that chemical reaction then using a 3m clear vinyl as a gasket between the hinge and body, then a respray. I'll have an independent body shop do it. Once and done!
Carolina Jeeper
Carolina Jeeper
Rollie
North Carolina
You are correct. The hinges do need to be removed and clean all of the corrosion off and seal at least to resolve this issue. The guy at the body shop made a comment about removing them to fix this time meaning they didn't the two other times. Hoping they do it right. I haven't heard back on whether it's approved this 3rd time or not. If not, I'll take it to my paint and body guy to have all four doors stripped and repainted properly.
Carolina Jeeper
Carolina Jeeper
Rollie
North Carolina
Hahaha! I know how hot that stuff is! I bought some Carolina reaper peppers a few years ago. They were too hot to eat for me. I dried some out and crushed them up to see if that toned them down. Absolutely still too hot!!!
new2jeeplife
2018 Jeep Wrangler
I am having issues with paint bubbling on hood and around door edges. How did you get this covered? My dealership says this is not covered under warranty. I also bought extended warranty. How do you all suggest going about getting this issue covered?
Bill_P
Bill
Orange Va
2018 JLU, 2023 JLUWSXR
Can't tell you..shhh
Go to a different dealer. That's what I had to do.
Carolina Jeeper
Carolina Jeeper
Rollie
North Carolina
I've had this repair done by two different dealerships. They don't pull the hinges off and the problem returns. I'm still waiting on the third decision to fix this again on three doors.
I'm at the point that I'm just going to accept the fact that a proper fix will only get done by a body shop I hire to do it right.
My doors still have no paint underneath any hinge after those two previous paint repairs. Absolutely not the correct way to fix this issue.
NeilP
Neil
South Dakota
2024 Jeep Wrangler Sahara Unlimited
RETIRED!
I took mine in a few days ago for an estimate. I've not seen it yet, but the body guy was guessing $6500-$8000 to repair it properly. So far it looks like it will be covered by the corrosion warranty.
new2jeeplife
2018 Jeep Wrangler
How does one find out if jeep is covered by a corrosion warranty?
NeilP
Neil
South Dakota
RETIRED!
The corrosion warranty is for 5 years starting from the "in service" date.
