BSD harness problems (Blind Spot) can't see left sensor?
FireAnt21
Tony
Wisconsin
2020 Sahara Unlimited North Edition
Lineman
Ok the pic looked weird to me. And maybe the block is not green lol. I was going off memory
rollerbones
rollerbones
Tom
Ohio
2022 JL 4xe
Network Manager
I think the passengers side is green block. That is where I wired the Rear Park Asset up to. (that cable I made myself, easy)
FireAnt21
Tony
Wisconsin
Lineman
Im made my own swapping out the power and led leads today. Got new mirrors and used sensors. Dunno if I need to program sensors to my vin.
rollerbones
rollerbones
Tom
Ohio
2022 JL 4xe
Network Manager
I don think you need to for the modules, they will automatically pick up your vin on the bus. If they are used they will just show the original VIN also with yours.
Here is my right side (only one I can see even if I only have the left plugged in)
You can see it will have the original VIN then your current VIN will populate.
Jeep Wrangler JL BSD harness problems (Blind Spot) can't see left sensor? j1
rollerbones
rollerbones
Tom
Ohio
2022 JL 4xe
Network Manager
This is from my wife's. She has 00 for right and 000f for left (these are hex addresses). for my right it is 00 and if I swap sensors the other is also 00 so I "think" that is my issues. I need to assign the left side 000f but when I try to set one it does not take (says success). Reading online I may need a "blue cable" that changes pinout to program but I am not sure yet.
Jeep Wrangler JL BSD harness problems (Blind Spot) can't see left sensor? Screenshot 2024-04-11 at 4.28.36 PM
Jeep Wrangler JL BSD harness problems (Blind Spot) can't see left sensor? Screenshot 2024-04-11 at 4.28.53 PM
FireAnt21
Tony
Wisconsin
Lineman
What obd adapter are you using and do you have bypass cable
rollerbones
rollerbones
Tom
Ohio
2022 JL 4xe
Network Manager
Using OBDlinnk MX+ with the security bypass cable. I know if I look with AlfaOBD it tells me to use a blue adapter cable (certain pins moved) to get to certain computers.
FireAnt21
Tony
Wisconsin
Lineman
Im pretty sure you don’t need the blue cable with alfaobd and Mx+
FireAnt21
Tony
Wisconsin
Lineman
I’m not at home to try. Waiting on doctor then I’m heading home
FireAnt21
Tony
Wisconsin
Lineman
Just finished rewriting same issues. Wiring was correct in the beginning. Just wanted to be sure. Does your harness connect to lighter for power?
Jeep Wrangler JL BSD harness problems (Blind Spot) can't see left sensor? IMG_2227
Jeep Wrangler JL BSD harness problems (Blind Spot) can't see left sensor? IMG_2228
Jeep Wrangler JL BSD harness problems (Blind Spot) can't see left sensor? IMG_2229
rollerbones
rollerbones
Tom
Ohio
2022 JL 4xe
Network Manager
Yes, mine does goto lighter for power. it also supplies it for the ParkSense. I have checked both sides and bot have +12 and grounds.​
If I plug only one sensor in to either side it still only shows the right module. It makes no sense, unless both modules are coded for right. I have been searching and still can't figure that out. There is no wire that tells them left from right side. There is only the wire that goes to the LED out put on the mirror but nothing designating right from left.​
Also, here is what is set from my wife's Wrangler that has factory blind spot:​
BSM on/off - Active​
BSM Left Blind - Active​
BSM/LBSM - Active​
RBSS/RBSM/RBSS - Active​
Active Blind Spot Present - Not Set​
Blind Spot Alert Menu - Set​
Blind Spot Mirror Present - Not Set​
Radio User Settings for Blind Spot - Active​
That is how hers is set from factory if it helps to check yours.​
rollerbones
rollerbones
Tom
Ohio
2022 JL 4xe
Network Manager
I think I figured it out and will fix this weekend. Has to do with the door harness. I dont have the signal control going back to the sensor for the left or right side. Easy fix, just some time to fix. The 2 wires per side going to each door, one is for the LED in mirror (other side is ground in door harness) the other wire is for the control (left or right) that goes back to the sensor!
FireAnt21
Tony
Wisconsin
Lineman
I’m pretty sure I checked continuity from door harness up to mirror. I ran wire from pin 12 of taillight to pin 21 of vehicle side of door harness. And I modified my door harness to have connections for turn signal and bsm. I’m lost now lbvs
rollerbones
rollerbones
Tom
Ohio
2022 JL 4xe
Network Manager
You have the correct harness from the connector up the inside of the door to the new mirror's also?
What I did, I replaced the glass in my original mirror that has Blind Spot indicator in therm. then I ran the Neg to a ground in door then positive of the indicator back to pin 12 of taillight.
The mirror glass I purchased: https://www.ebay.com/itm/126350234086 then cut cable and grounded the black and the red went back to BSD driver.
FireAnt21
Tony
Wisconsin
Lineman
I bought mirrors with blind spot. I believe last I checked I had the correct door harness but I think I’m going to look and check tomorrow. I do remember adding wiring but I think that was for the turn signals. I did not add a ground so maybe that’s it.
