Broken axle?
Moto_21
Erik
Corona
2018 JLU Sport
Maintenance
Guess ill start to go a little slower on the trails with my non rubi then :cwl:
Bic
Richmond, VA
Ocean Blue Unlimited Sport S
That’s what happens when you put larger tires on a vehicle that wasn’t designed for them without the appropriate supporting mods.
River City Offroad
Marcus
Dripping Springs, TX
www.RiverCityOffroad.com
2019 JLUR Triple White - RK 3.5" X-Factor Stage 1 / Steer Smarts / Mickey Thompson / Fuel
Owner at River City Offroad
It was not a simple axle failure. :)
Solidaxle
Beautiful Ventura county California
2019 JL 2 Door Rubicon
That’s a common housing failure with the three-piece front axle. With the FAD or EDD. Remember these type of stupid housings are not new they were used in the Dodge straight axle trucks in the old jeeps and they did the same thing if you abuse them. A company called Dyna trac does a conversion and they get rid of that two-piece and replace it with a one piece. The axle tube itself is strong it’s the cast piece that they press into that breaks where the axle coupler is for the axle disconnect.
The Fix What you’re going to see as a fix come first is there going to have a steel tube that they pound in the inside to give it some extra strength we’re all these pieces pressed together that will be the most economical cheap aftermarket fix that you will see first.
Martindfletcher
Martindfletcher
Martin
San Diego
Ducati 1299s, 2018 JLUR
Based on what @Kevin8086 and Brit are doing with jl on 38’s there is a real story with this one,
spurly
Zach
Nebraska
2019 Bright White JLUR
Saw on a post (Instagram I think) he went full send with 38's, but wasn't confirmed. I think if I was running 37's or larger I'd consider an axle truss just to be safe. Of course I wouldn't be going all "Hold my beer, watch this." in my rig anyways.
Boston Mike
MIke
Dallas, Texas
2018 Black JLU Rubicon
posted in my local jeep site. Owner said that they were wheeling at night and did not see a tree stump that they hit (obviously at a good rate of speed). Guess he needed a bigger light bar.
JMyatt
Manchester, NH
2018 Wrangler JLU Sport S
Jeep Wrangler JL Broken axle? 500000F8-00A7-4111-97B0-74A83D9D7EB0
Jeep Wrangler JL Broken axle? A2349F44-4120-44E8-9D58-F41B79AD63E5
Hey everyone, so I have been investigating the steering wobble issue on my new JLU. It’s stock. No upgrades. 1200 miles now. The problem is getting worse. So I put it on a lift and started checking things were properly tightened myself. Everything seemed to check out. One of the techs at my buddies shop noticed this. It appears the axle weld has failed and the tube is moving inside the differential case. Anyone experiencing this issue on the JL yet? Could this cause the wobble or be the issue in this guys axle breaking. I don’t know but it’s a concern. See pics.
Jeep Wrangler JL Broken axle? 2D45DF43-1E7A-499F-BA23-20144399F582
Jeep Wrangler JL Broken axle? B72062E6-0946-494D-A006-89587FC78345
Jeep Wrangler JL Broken axle? 844E4D2D-75DE-443B-A9B6-BC2EC12E901B
NFRs2000NYC
NYC/NJ
2014 Jeep Wrangler Unlimited Rubicon
Going fast and smashing into a hidden rock.....just because you could doesn't mean you should. That is clearly a blunt force impact.
  • Like
Reactions: J0E
