BOLT padlock--what is the max inside width it will close on?
STW
2022 JLR 2door 2.0T Rubicon stingrey
Quick question for anyone who has the BOLT padlock--what is the max inside width it will close on? It says 2" shackle but don't know if 2" is the straight part of the shackle or the max it will close on. Thanks!
Terrymo
Terry
2023 JLURXR 3.6 ET
Is this what you’re asking? If not let me know I’ll take some measurements.
Jeep Wrangler JL BOLT padlock--what is the max inside width it will close on? IMG_1137
  • Like
Reactions: STW
STW
STW
Thanks! I'm looking for the max inside shackle length--I subtracted .311" shackle thickness from 2.14" ouside shackle height, and that should be pretty close. The diagram makes it look like there might be a bit extra distance between the shackles since it measures to the flange and not to the base. But pretty close.
STW
STW
thanks Medsker and Terrymo!
DaltonGang
Doesn't Play Well With Others
What are you using this bolt for, on the Wrangler?
