Bolt hood lock / Hate the look
Flip
Johnny
Virginia
2023 Jeep Wrangler Sport
Retired Power Plant Engineer
ACAPECE
ACAPECE
Anthony
Staten Island
2024 Willys XR
MichaelT333
Delaware
2022 Willys
Hey if your looking to sell the grill you cut up I will happily buy it from you
Wylie E. Coyote
So Cal
2023 Wrangler JL Sport Altitude
About a month ago I installed a bolt hood lock on my 24’. Since the grill is re-designed they supplied a template to cut away parts of the grille to accommodate for the key. I hate the look. The gap is way too big, people have asked if it’s a charging port ?.
Before buying a new insert to experiment on I was curious if anyone cut away less than the recommended pieces? if so can you supply some pictures. Or if anyone has other ideas or suggestions
Before buying a new insert to experiment on I was curious if anyone cut away less than the recommended pieces? if so can you supply some pictures. Or if anyone has other ideas or suggestions.
I actually went with the old fashion cable lock. I found two small holes in the hood, ran a coated steel cable through the holes and locked the ends together next to the secondary hood release. I did not want to cut into the grill, and a friend told me he has seen those Bolt locks fail.
FedeWrangler
Federico
Italy
Wrangler Rubicon Recon 2020
Here are close up pics of the '24 factory insert. As others have stated, its the ENTIRE grill insert and not just the middle part like the '18-'23 part. The hole is much bigger than necessary.
I'm looking for this piece. where can I buy it?
Halxen
Patrick
'24 Wrangler JLURX
AC77
AC Abegian
Los Angeles
Autobody , singer-songwriter
i recently installed the Lasfit hood lock, hidden and great product, easy to install
FedeWrangler
Federico
Italy
https://www.allmoparparts.com/sku/jljtrubi20agrillehl.html#col-fitment
EDIT: For clarity the part number for the insert is 7HR05RXFAA but I couldn't find it separately from the whole grille kit. Maybe @AllMoparParts.com can chime in and let you know if its available separately.
@AllMoparParts.com news?
Sanchese
Carlos
Toronto, Canada
2021Rubicon, 2022 Rubicon Xtreme Recon on Order
Since you’re now buying a new grille insert (btw, it’s the whole span of the grille), why not just buy the one designed for the Mopar hood lock?
I have one on order for the 2024 grille I’m going to install on my 2019.
For those who cut up their 2018-2023 grilles, Mopar has an easy to replace, centre piece with a cutout for their lock.
What is the part# for this?
I have the trail cam on my 2022 rubicon and would like to add the bolt lock.
JPAloha
Saskatoon
2019 JL Rubicon 2 door, 2022 JL Rubicon 4xE, 2018 JL Rubicon 2 door
Accredited Financial Planner
You would lose your trail cam by doing that. Maybe take a look at the Lasfit lock that operates off the remote door locks.
Casper_
Casper
AZ
Jeep 392 2024
I have Lasfit and highly recommend. The only caveat is that (unless they've updated the design since Jan), the inside bracket for the emergency release needed modifications for the 2024 MY.
AllMoparParts.com
Peak Sponsor (Level 2)
Benny
NY
2018 JL
