sandygar4
- Thread Starter
- #16
My problem was that a pin in the passenger door plug was bent. I had the doors off and and when I plugged the door harness back in a pin got bent and caused a short. Straightened the pin and the problem was solved. I thought I was careful when I reconnected the plug, apparently not careful enough. If you're having trouble with your blind spot warning system it gives you one more thing to check.
