Bicycle carrier
JINO
JINO
Jino
Socal
2021 jlurd
Yea ask dealer if they can contact the previous owner, the owner probably forgot and might want it.
They don't have their info.
melendez69
Marc
Waxhaw NC
...huh?
I've had the Hollywood Racks on a 35 for over a year now with no problems. I'd have preferred a hitch-mount, but only last year did my lady decide we should would bike ride more often.
$200 bucks later I regretted not getting the tow package back in 2018. Sooooo many, many more selections.
Heimkehr
Pennsylvania
2021 JLU 2.0T
Came across a really big issue.
Lifted my hitch cap, and found out there's a safe in the hitch! Wtf.
Dealer had no idea, and they don't have the combination.
Is there a way to get this out??
Ah, the HitchSafe. I received one as a Christmas gift a couple of years ago.
If you can make a simple metal shim, you should be able to DIY the removal:
Raisekayn
Kathleen
Tampa, FL
2017 Mini Cooper
I'm new to the forum and came across this post. Did you figure it out? We had one on our Tundra. Those pins are grade 8 steel. Not sure you CAN get it out unless you can drill out the silver pins. Curious to know your outcome.
Pirate63
Alan
Eastern NC
2021 JL80
Do you need an extender for the 1UP quick rack?
I didn’t need an extender, but my spare is only 34” (LT285/75R17). I also requested the reverse brackets when I ordered my 1Up, which angle the rack down instead of up.
Jaysfan81
Montreal
2024 Wrangler Willys
I need a bike carrier for my JL with a 38x13.5x17 spare tire, either hitch or spare tire mounted.
Could anyone recommend a mount?
TiA
I purchased a Hyperax 2024 Volt 2 for our 2 e-bikes. It's been great and has a max capacity of 160lbs. The bikes did fit but the bike's pedal closest to the spare would rub against it so I purchased a hitch extender which provides plenty of clearance.
JINO
JINO
Jino
Socal
2021 jlurd
It was no match for the hackzall. Less than a minute and it was off.
Jeep Wrangler JL Bicycle carrier 20240921_175915
vaJLUR
NC
2020 Jeep JLU Rubicon
I use a Kuat Pivot + Sherpa, clears my 37x12.5 with plenty of room to spare.
Only pic I can find right now but will take one tomorrow with the swing closed if it helps you at all.
The Pivot has an added benefit of being used with a basket, too.
JINO
JINO
Jino
Socal
2021 jlurd
Oops late reply.
When i got the first bike, the seller threw in the bike rack. It holds both bikes fine.
Got a 2nd bike for the wife, both are dual motors and a hoot to ride.
Had to return a single motor bike, as it could not go up my 19° driveway, which is about 1200' long. Was not fun pushing a heavy ebike up that.
Says it does 40 mph, got it up to 35, but 35 mph is not realistic on a bike IMO, you need full protective gear at that speed. We keep it around 25 mph max, as we don't even have helmets yet.
Jeep Wrangler JL Bicycle carrier Screenshot_20250208_200214_Facebook
Jeep Wrangler JL Bicycle carrier 20241028_141842
Jeep Wrangler JL Bicycle carrier 20241028_162732
