Ah, the HitchSafe. I received one as a Christmas gift a couple of years ago.Came across a really big issue.
Lifted my hitch cap, and found out there's a safe in the hitch! Wtf.
Dealer had no idea, and they don't have the combination.
Is there a way to get this out??
I'm new to the forum and came across this post. Did you figure it out? We had one on our Tundra. Those pins are grade 8 steel. Not sure you CAN get it out unless you can drill out the silver pins. Curious to know your outcome.Came across a really big issue.
Do you need an extender for the 1UP quick rack?+1 for 1Up![]()
I didn’t need an extender, but my spare is only 34” (LT285/75R17). I also requested the reverse brackets when I ordered my 1Up, which angle the rack down instead of up.Do you need an extender for the 1UP quick rack?
I purchased a Hyperax 2024 Volt 2 for our 2 e-bikes. It's been great and has a max capacity of 160lbs. The bikes did fit but the bike's pedal closest to the spare would rub against it so I purchased a hitch extender which provides plenty of clearance.I need a bike carrier for my JL with a 38x13.5x17 spare tire, either hitch or spare tire mounted.
Could anyone recommend a mount?
TiA
Post #19.I'm new to the forum and came across this post. We had one on our Tundra. Those pins are grade 8 steel. Not sure you CAN get it out unless you can drill out the silver pins.
It was no match for the hackzall. Less than a minute and it was off.I'm new to the forum and came across this post. Did you figure it out? We had one on our Tundra. Those pins are grade 8 steel. Not sure you CAN get it out unless you can drill out the silver pins. Curious to know your outcome.
