Best shocks for the beach?
RoadSahara
United States
2020 Jeep Wrangler Unlimited Sahara (JLU Sahara)
Hello everyone. I’m looking into getting new shocks for my JLU Sahara. I drive on the beach a lot, which is why I want to replace the Zone lift kit (the previous owner installed it). The issue is, the current lift has no travel and it makes me crawl on the beach and it makes it unbearable on the road. While there is washboarding, I have to go like 5~mph and I get passed by everyone. I’m also suspecting that one of the shocks is about to go. What do you all recommend for shocks that would be good for the beach? My budget is around $600-$800 and I’m not looking for Baja truck travel, but something with a little more travel on a budget and that gives me a 2-3” lift from the factory height. Thanks!
Flip
Johnny
Virginia
2023 Jeep Wrangler Sport
Retired Power Plant Engineer
I suggest doing a whole lot of research before installing 3 inches of lift. If you're going to lift, I would also suggest changing your shocks when you install or have your lift installed. This will prevent changing your shocks twice ✌. Lift kit recommendations; IMO, I think something similar to an AEV lift kit would work well for your needs. Rubi take offs are also an option to save $$ especially if you plan to do the install yourself.
Best of luck my friend. 👍
CloakedWillys
Summit Sponsor (Level 3)
Will
Rancho Cordova, CA
www.metalcloak.com
18 JL 2.0T Sport S
Sales and tech support for MetalCloak
That is a little open ended. If you are just driving on the sand at 5-10 mph the shocks don't matter much and you will want to focus more on the road ride. If you are playing in the dunes and running at speed shocks get spendy to get somethign that will stay cool.
I am thinking the kit you have may need some dial in along with fresh shocks depending what you have. Also lowering tire pressure in the sand will help.
RoadSahara
United States
Hey thanks for the reply! It’s already on a 3” lift, I meant that I wanted to keep the lift height, as the current Zone kit is a 3” lift. But I’ll look into the AEV kits and the Rubi.
Flip
Johnny
Virginia
Oh ok, I understand. If just replacing shocks, Metalcloak offers some nice shocks, Fox, Falcon, King, AEV/Bilstein to name a few. A lot of good shocks out there. Btw, they are very easy to install.
RoadSahara
United States
Yeah sorry I meant I would like to drive a little faster on the sand. I know the ride won’t be smooth, but shocks that will allow me to go faster than crawling on the beach.
RoadSahara
United States
Oh ok, I understand. If just replacing shocks Metalcloak offers some nice shocks, Fox, Falcon, King, AEV/Bilstein to name a few. A lot of good shocks out there. Btw, they are very easy to install.
I see, I’ll do some more research. I’ve been looking around Bilstein and Fox, but I’m open to other brands.
CloakedWillys
Will
Rancho Cordova, CA
www.metalcloak.com
18 JL 2.0T Sport S
Totally get it. Also why I mentioned tire pressure. Its amazing what going from street pressure to 15psi will do in the sand.
As far as the amount of travel the kit you have as, is it limited by the shock or somethign else? I can help you with that if you want to reach out.
RoadSahara
United States
Yeah I usually air down to 15-20psi and I actually went back to all seasons for the winter, the 35s had dry rot. The travel kit is limited by shock. I have the stock springs, but I believe the kit came with sway bar links, shocks, and a couple of other small things. I don’t think they’re adjustable, but I’ll check Zone’s website again.
RoadSahara
United States
Flip
Johnny
Virginia
@RoadSahara
Other jeeps were passing me on the trail. I started asking, what am I doing wrong? I wasn't disconnecting. Once I did, OH geez, what a huge difference! This really helped soften the ride. Something to consider anyways.
RoadSahara
United States
@RoadSahara
How difficult/expensive are sway bar disconnects? I’m in a Sahara.
Flip
Johnny
Virginia
I run Apex quick disconnects, they're pricy ($400) but I'm old and have arthritis in my spine. There are plenty of other quick disconnects that might require laying down but you'll be on a sandy soft beach (lucky).
Jeep Wrangler JL Best shocks for the beach? 20251122_120033
RoadSahara
United States
I see, I’m assuming those you just disconnect from the top or side? Sorry I’m fairly new to suspension mods, especially on Jeep.
Flip
Johnny
Virginia
Yes, just turn the blue knob 180.
I sent you a link for a few different quick disconnects.
