lclewis49
- Larry
- Dec 16, 2018
- mesquite nv
- 2018 JL rubicon
- Occupation
- Retired
The feature that I liked with the jl CoolTechLLC kit is it elimated the need for the brake light relay if you use a suplental braking system that presses the jeeps brake pedal. . Also all the connections are inside the vehicle and minimal splicing. In addition CoolTechLLC provides a output wire that can be used to light up an led when the brake system pushes on the towed vehicles brake pedal. The downside is you have to remember to set the switch to the proper position, either tow or Jeep. With my prior jk I did have to install the Roadmaster brake relay to have the brake lights work properly with the smi Air Force brake system I was using. Although it always functioned properly I have heard of them failing and causing strange problems with the Jeep. With my new jl I plan on using the CoolTechLLC kit for now. If mopar ever comes up with a kit I may reconsider. And yes it would be nice if CoolTechLLC provided a nice install video.
