Beefing up my tires
Timdav671
Bronco
I just bought a new Jeep Wrangler rubicon 2021 with stock rims 17x7.5 and I would like to put on larger tires. What is the largest I can go without any other modifications? This is mostly for appearance and not off-road use. Thank you!
dchemphill1
Nebraska
2020 Wrangler Rubicon Recon
School Administrator
35" tires will fit on Rubicon. The width of the tire will be limited by the rim. To fit on your rim you can get 35x11.5x17. If you look at tire manufacturers data it will tell you what rim width you need.
jadmt
jeff
montana
Mickey Thompson baja boss at in 255/85-17 is a 35x10 and fits perfectly on a stock wheel. some don't like skinny tires but they do really well in the real world if you can get past the looks. this was before the lift.
Jeep Wrangler JL Beefing up my tires IMG_5689
Blues Fan 30
St. Louis
All you rubi owners and your capable gearing...I'm just gonna go sit in my jeep and pout about the stupid sahara 3.45 gearing and my 33s.
Tokenwasp
Atlanta, GA
2021 Wrangler JLU 4xe Rubicon; 2008 Saab 9-3 Conv.
For width, you can go up to 295/70R17 (about 11.9 inches wide) under most tire manufacturer's guidelines.
However, if you aren't off-roading, then you may want to go by the Discount Tire guidelines. They will install up to 12.5 inch width on a 17x7.5 inch wheel.
Fergshouse
Tennessee, USA
2020 Sahara North Edition
Anybody know tall a tire you can on stick Sahara suspension with 3/4” Daystar spacers?
GrayWolf.Overland
Subash
Maple Ridge, BC, Canada
2025 JLU Rubicon (Anvil Gray)
What look are you going for? Fat wide tire with jeep sitting low..it tall skinny tire with tread tucked into fender
Fergshouse
Tennessee, USA
I’m running 285/70r17 with aftermarket 17x9 wheels with 4.5” BS, so looking at a little wider (maybe 12”) and would like to go to a 35” tire. I don’t do much offroad, mainly trails so no need for massive articulation. Mainly for looks.
Blues Fan 30
St. Louis
The real question is what size tire will the sahara gearing allow and that is 33". With proper gearing you could PROBABLY run 35s with the daystar lift if on road use only. If you're offroading then back to 33s again.
Cips
Anthony
Bucks County PA
2021 Wrangler Unlimited Willys
Sales
I put on 35"x11.5" on 17"x9" (4.5"BS) with no lift. Do the front wheels first and check for rubbing. I had plenty of clearance.
Jeep Wrangler JL Beefing up my tires PXL_20240803_011646722.MP
I'm still on 3.45's.
Zandcwhite
Zach
Patterson, ca
2019 jlur
Even the non-rubi models have plenty of gearing compared to the JK. The 3.8Ls came with a 2.86-1 1st gear. The 3.45s with the 4.7-1 1st gear are like a JK with 5.67 axle gears as far as 1st gear/crawl ratio. You'll be fine on 35s.
Odyssey USA
Daniel
www.youtube.com
2021 JLU Rubicon
I’ve been a pizza cutter guy for a couple of years now, before this video came out confirming my results. No loss in performance. Fat tires are a mostly aesthetic mod now.
