BEADLOCK MAINTENANCE AND USAGE??
Joaquim
Joaquim
Boulder
2018 JLU Sport S
Autist
I currently have method racing (MR305 model I think) wheels with 35 Inch tires mounted - how often should I be tightening these beadlock bolts? What torq specs should I tighten them too? Is there anything else I should be aware of? I also know they are technically not street legal because they have beadlocks - but I’ve never heard of that being enforced??
Rangemaster
Nevada
2020 JL Rubicon Diesel
Business Owner
I also have Method beadlocks, I just checked the torque on my the other day after 1000 miles and only a handful needed to be adjusted. The wheels come with a sticker that says check every 300 miles.
Jeep Wrangler JL BEADLOCK MAINTENANCE AND USAGE?? 3D3BC26F-E931-4272-A9EC-8B2E6EA26A10
Joaquim
Joaquim
Joaquim
Boulder
2018 JLU Sport S
Autist
What specs do you torque them to? I don't have an impact or anything just a hand ratchet.
Rangemaster
Nevada
Business Owner
Mine state 18 to 22 pounds. I torque them to 22 pounds and everything is good.
AcesandEights
Aces
So. Oregon
2024 Toyota 4Runner
Inch pounds or foot pounds?
firedude
Bret
AZ
2022 Rubicon XR 392 Stingray
Retired firefighter
.I go over them after the first 100 miles. Then again after another 100. I did not get any loose bolts on the second time around. IF I did I would keep checking them at a hundred until they stopped loosening. I will now check them at every oil change (3000 or so). I torque them to 20 ftlb. This is my third set of method beadlocks. After initial set in they have not really loosened up on me. I use anti seize when installing them. If you really beat on them I would stick to their recommended 300 mile check.
