Battery/Starting Issues
PMyers21
Phil
Toledo, Ohio
2018 Sahara
Photographer
I've been having some random starting issues the past week and was hoping someone may know the answer.
A few weeks ago I didn't have remote start, ESS, and after what I thought was the fix, I replaced both the AUX and Main batteries. Fast forward to this past week and it did it again. Jeep just won't start, after looking into it again and trying a few things I disconnected the main battery all together leaving just the AUX battery connected and it started right up.
Would that mean the Main battery I just replaced is already bad? or something else?
Gregj
Greg
West Texas
My guess is the high amp fuse array. They are the main fuses on the side of the fuse box.
Gregj
PMyers21
PMyers21
Phil
Toledo, Ohio
2018 Sahara
Photographer
I just checked that, had to pop off the black piece to see the fuse connections. All looked in tacked. It did have some slight discoloration, but all were connected.
mwilk012
Oklahoma
2018 Ocean Blue JLU Rubicon
Service
You cannot visually check them. Do you have a multimeter?
58Willys
Geoff
Western Washington
2018 JL Sport
Are your new batteries fully charged? Just because they are new, doesn’t mean they have a full charge. Batteries should be 12.6 to 12.8 volt at full charge. Check that first, then check and make sure all cable connections are tight, including ground cable terminations. If all that is good, check fuses, then check for parasitic draw.
PMyers21
PMyers21
Phil
Toledo, Ohio
2018 Sahara
Photographer
Just took both the AUX and Main to Autozone and they both checked out good.
When I removed the AUX battery the negative post was wiggly, so we’ll see if that was the culprit once I get it back in.
PMyers21
PMyers21
Phil
Toledo, Ohio
2018 Sahara
Photographer
Update: I got it started, took it to the dealer Sunday. They called Monday and it was a bad starter. $900 repair ?‍?
Old Dogger
Bill
Cave Creek Arizona
It is good that they found the problem. Also make sure that your battery terminals are tight.
Boutch76
Yannick
Vancouver
2018 Jeep Wrangler Sport JL 2D Manual
but a recliner seat?!?!?
[/QUOTE]
I have had the same problem. My 2018 Jeep JL has had more issues than my Toyota 2005 Corolla. I regret my purchase and will never buy a Jeep again
