Starting issues, no crank no start
Dylan P29
Dylan
2018 jeep JL
So my 2018 JL with 105k miles just began giving me issues. I was having intermittent starting issues. Found the starter covered in oil from a cracked oil filter housing. Replaced housing and starter. Continued having intermittent issues, no codes stored. Replaced both batteries and the batteries in the fob. Kept having starting issues with no codes but it continued running well once started. Continued driving praying for a code to be thrown then after about a month I woke up to it dead in the driveway. Code was thrown as a crankcase position sensor. Replaced that and still has no crank. Can hear the the fuel pump kick on. Back to normal codes and a dead jeep. I checked all the grounds and cleaned them up. Fuses are all good. I’m thinking it may be the neutral safety switch? Has anyone else had this issue and what else should I check?
