83 Shellback
- Aug 5, 2025
- Northern, Virginia
- 98 Jeep Wrangler, 17 Ram Rebel
Long story short, garaged / not-in-use 98 Wrangler Sahara. Battery dead (understandable)
Charged battery. Starter died while cranking in attempts to start (+25 yrs old). Replaced starter, then battery. Started okay, drove a short distance (maybe 5-10 miles) and put back in garage. Wasn't too concerned with it being unused in the garage since I have a charger and can jump from another vehicle. Also, figured I'd start it every month or so (failed to do that).
Fast forward to recent. Now, I have it on a tender to keep the battery topped off. When I try to start it, it cranks over once from a full charge and then battery dies (clicks like drained battery or maybe solenoid issue).
Jumped it and took it to a nearby shop. Figured alternator since it didn't seem to be charging the battery - though, admittedly, I probably didn't drive it far enough to charge the battery. Think if it jumpstarts okay, that means the solenoid is probably ok..
Anyway; Shop just called me and said the alternator is fine - the problem is that I have an AGM battery but those are for vehicles with a lot more technical requirements than my 98 Wrangler (touchscreens, backup cameras, heated seats, etc.) which has none of that. Said AGM batteries sometimes don't charge properly from the original alternator in the Jeep. They also said the battery wasn't charging (said it showed 0%).
Approved getting a new, non-AGM battery, but does that sound legit?
