Baja Designs LP6 wiring HELP needed (Mental Block)
Ct_Formula
Orange Ct
2021 Rubicon JL, 2011 JK Sahara
Self Employed
Ok I finally got my LP6's after 5 months of waiting and $1000 later. Now I open the boxes and realize that I can't simply use a single hot lead to one of the OEM switches and tap the DLR for the backlight and be done.
I didn't get any harness with them, but for some reason I bought 2 64-0177 s8 backlit Addon wiring harness. So now I'm really scratching my head.
Do I need a harness to us the OEM switch in the dash? I only want HIGH and backlit, will the OEM Switch handle it?
Any recommendations or ways to go? I have mental block for some reason on these it's driving me nuts.
Thanks in advance
BeechAV8R
Roger
Southern CA / Northern AZ
Rubicon 392, CJ7 6.6L, Fusion Trophy Truck
Aux. switch #1 or #2 will handle the current draw (Amps) of the LP6's.
Hook up the lights as below:
Pin 1. (low beam) leave disconnected.
Pin 2. (Ground) hook it to chassis ground or battery Negative.
Pin 3. (Amber Back Light) tap into either driver or passenger front side marker lights.
Pin 4. (high beam) Hook this to either #1 or #2 aux switch leads to provide +12 volt power to the lights.
BajaDesigns should have provided a 4 pin female Deutch connector with pins with each LP6 light.
Willing&Able
IL
2023 392 20th Anniversary
I just installed the LP9's last weekend. Amber backlight w drivers side side marker, lows on aux1 and highs on aux2 of factory aux panel. Works perfect. I do have many feet of excess I need to cut and butt splice together. Currently shoved between battery and fender.
BeechAV8R
Roger
Don't put power to Pins 1 (low beam) and pin 4 (hi-beam) at the same time....Or your light's circuit board will go up in smoke.
Ct_Formula
Ct_Formula
Orange Ct
Self Employed
Beech, thanks big time. Worked like a charm!!! These things are crazy
Willing&Able
IL
Not sure why everyone is not connecting the low beams. They aren't just a weaker version of the high beams. I find the lows are more of a flood with a wide arc of light (still bright) whereas the high beams are a very intense spot beam. In the midwest I'd likely use the low more than the high.
And correct, don't use both at the same time - although I believe the wiring harness has a measure of protection to prevent frying your circuit board. I'm not going to test it out...
Ct_Formula
Ct_Formula
Orange Ct
Self Employed
Yeah I only need them on all or nothing. I'm only going to use the 4 OEM switches in my build so I have to preserve the other 3 for other lights.
brewski
Jack
Washington
JLUR-diesel
I use my lows mostly and rarely use the highs. In the PNW you don't get those long open terrian you get in the desert climates. It is very rare to need that length of light cast and if you have too much light shining into the trees/bushes then it shines back at you and blinds you, especially when it is wet out. The lows are great and very effective .
Ct_Formula
Ct_Formula
Orange Ct
Self Employed
Yeah I'm all amber, I can't use the clear around my neck of the woods as much. And I really like the fact that that there is less bounce back in rain fog and snow with amber
Compression-Ignition
Roy
Montana
Is that how they work? I'm gonna have to ask my guy and see if he knows. That's the first I've heard/read anybody describe the difference between the BD lows and highs like that.
I just had my first chance to see what this 20" onx6 looks like and all I could tell is that it was a little less strong on low. The snow was coming down pretty good so all the reflections didn't help in trying to see what the output was like.
You need to head over the mountains and check out the dry side some time. It may not be the flat lands, but there are plenty of wide open stretches. I'm just saying the entirety of the PNW is not the coast to the Cascades.
supermike
mike
Irvine CA
18 JLUR 6 speed 2021 JLUR 392
you can buy something like this to tap into factory wiring without cutting to use the back light. Aux 1 is enough for your high beam draw. also you can buy those Deutsch Connector and crimper on Amazon.
Jeep Wrangler JL Baja Designs LP6 wiring HELP needed (Mental Block) Screen Shot 2022-02-16 at 11.25.07 PM
Jeep Wrangler JL Baja Designs LP6 wiring HELP needed (Mental Block) WechatIMG307
Willing&Able
IL
At least on the LP9 Pros. I'll take pictures this weekend facing the lights and from the drivers seat so you can see.
Willing&Able
IL
The BD wiring harness came with an inline splice for that worked perfect with the drivers side marker light.
I did have several feet of excess wiring. I bundled and tucked away between battery and fender. I'd like to clean it up. Did others cut out a section and splice together as well? What kind of splice did you use?
supermike
mike
Irvine CA
I made my own wiring, the wiring hardness bd has is wonderful but I’m too cheap to buy it. Would rather use that money to fill my tank up. In line splice is too convenient for corrosion to grow btw.
BeechAV8R
Roger
Good to hear that you got them working!
I just installed 4 LP6's on the front bumper of my old faithful CJ7 rock-crawler and used them up in the snow/mountains last night for the first time. They work 100X better than the old HID's that they replaced!
