BADLANDS 12K WINCH NOT FITTING
DEdney1775
DEdney1775
Daniel
Baton Rouge, LA
2020 2.0 Sport
Not the best idea, adjusting the bumper would be my choice, slotting mounting holes on either the bumper, or winch mounting would be my choice. This will take some heavy duty power tools to do this.
I'll take a better look @ the bumper this evening after work to see what my options are for trying to get it out a little further.
Narb16
Bryan
Los Angeles
2021 Jl 80 anniversary
If the rope is touching and the grille is fastened firmly , you could shim the bumper forward . You can also run the cable out of the side of the cover
Jeep Wrangler JL BADLANDS 12K WINCH NOT FITTING DFC393DD-0108-4B5E-B549-052429F439DF
How’d you do this?
GATORB8
CLT NC
21 JLURe
Just a note if you decide to use the DV8 spacers. They push it out 2", but if there are any secondary brackets used to install the bumper (winch plate or bar support as on my RR) it may make those brackets not fit.
Hotchyy
Romeo
Tampa, Florida
2020 Jeep JLU
Parks & Rec
Had the same problem with a Warn plate. Does anyone have the link for the mentioned thread about taking the wires out the side?
SlickRickMotoADV
El Sobrante, CA
2019 Wrangler Unlimited Sahara, 2017 Miata Club RF
+1 for spacers. Same thing happened with my aftermarket bumper and winch. Added in a 3/4" spacer on each side and all is good now.
GSLSE21B
Fair oaks
2021 jLURD
If you use a spacer , make sure your plate is tied into the frame . The only thing worse than being hit with a rope , is being hit with the whole bumper/winch assembly
PocketsEmptied
NC
'08 JKUR, '21 JLUR
damageinc321
2018 wrangler rubicon unlimited
Jeep Wrangler JL BADLANDS 12K WINCH NOT FITTING EED2330A-9F34-444F-BCFD-BD5C960ABCFF
How did you remove the clutch handle to cut it down?
damageinc321
It has a set screw on the side of the handle
I took out the set screw and pulled up pretty hard and it wouldn't come out. I tried turning it while pulling up at different points but it didn't come up at all. Did you use a pry bar?
