Axle reinforcement or not
TNShaker
Baker
Smyrna
2024 Wrangler
I have a 2024 JLU Sport 3.6 auto that I am hoping to build out this year, I have most parts planned and I will be doing 2.5 Clayton lift with 35" tires, re-gear and Eaton TT front and rear. I will not be rock crawling ever, just street and some TN mountain trails. The one thing i am not sure on is should I do anything to add strength to the axel, ball joints and c gusset. I assume since staying at 35s I should be OK, but since I do not have Rubicon axels I am not positive. I do not ever plan to go over 35s for street ability and do not want to do an axel swap.
Trails
'24 JLUR 392 F.E., '89 Bronco (retired), '04 Ram Cummins (hangin' in there).
What type of trails will the TN mountain trails be like? If they are just gravel / dirt roads, then I wouldn't do anything. A stock Sport is plenty enough. Save the money, and spend it on a fun trip somewhere.
Odyssey USA
Daniel
Indiana
www.youtube.com
2021 JLU Rubicon
As to strength of the housing itself, compared to a Regular JL Rubicon, same strength. The axle tubes are the same wall thickness and diameter. If you’re taking some tight switchbacks, switching from u joints to RCV axle shafts would get rid of hopping in 4wd with the steering at full lock. If you regear and have the M200 rear, you can upgrade to 32 spline Gladiator tow package narrow axle spec Yukon forged axles with a different carrier. Ox Locker is what I used in the rear to accomplish this. Great setup. That said, the weak point becomes the smaller pinion vs the M220 but I’ve not heard of a M200 breaking there since I joined the community 5 years ago. I opted for the electric actuation. 4.56 Dana gears btw.
Stuckinthesand
CJ
NJ
2019 Wrangler Sport S
I’m on 35ā€s with the stock gears on my 19 sport s. Only thing I do is rocks(blue rated or a blue/black) and have been fine with no reinforcement. Once my stock gears go bad my plan is to add the TT and probably 4.56 also.
AcesandEights
Aces
So. Oregon
2024 Toyota 4Runner
Nothing you need to do. Chive on, or whatever they say.
roaniecowpony
Retired Engineer
If you don't bomb down the roads and hit large bumps, reinforcement isn't needed. Trussing is for that really big hit.
kah.mun.rah
Merenkahre Jr.
Duat
IMO unless you are a balls to the walls kind of driver, the JL axles and c's are pretty solid as-is for 35s. That said, when I had mine regeared since the axles were disassembled anyway, and welding trusses on them was only a few extra hundred, I went ahead and had it done. Again, I don't think I need them but they look cool if anyone is ever looking up under my skirt.
TNShaker
TNShaker
Baker
Smyrna
2024 Wrangler
Some decent slopes, creeks, mud. Not trails I would do in a stock sport but I never planned keeping it stock. My JKU had the lift and lsd too, never needed my winch.
zouch
Berkeley, CA
XJ, JLUWD
i'm going to ASSuME your lift includes all the proper steering bits (adjustable Track Bars and rear relocation brkt, Drag Link, front Track Bar/steering box reinforcement, Tie Rod) and probably longer/adjustable LCAs.
i'm not as familiar with what;s under the '24s, but i'm also assuming you've already verified you're not working with the Aluminum Steering Box or Knuckles, or i'd get those updated first.
but especially since you mentioned it, i'd be looking at doing a set of proper replaceable heavy-duty ball joints while you're there just to help address one of the most common points of failure leading to Death Wobble.
the factory plastic ball joints are junk; running with even 35s will make that evident much more quickly.
after that you sound like you're on a good track to having some sane fun. enjoy!
TNShaker
TNShaker
Baker
Smyrna
2024 Wrangler
That is what I was considering, it will be all disassembled anyway so if needed then would be the time.
TNShaker
TNShaker
Baker
Smyrna
2024 Wrangler
I did figure ball joints at a minimum, plan on spending a few grand so those don’t add a whole lot to the cost.
dragoneggs
Seabeck, WA
'22 Snazzberry Pearl JLR
If you aren’t using your winch, you ain’t trying hard enough. :LOL:
jbcrane
40.5853° N, 105.0844° W
Just a Jeep, M'am.
3D Animation
You should be just fine as is. I did the 2" Mopar lift and went to 315's on my M186/M220 set. I also re-geared to 4.88. It's been 2 years and multiple trails more difficult than what you're describing and it's solid as a rock. When time comes I'll upgrade ball joints, etc. but for time being everything has help up great. Your driving style has a lot to do with it too.
Jeep Wrangler JL Axle reinforcement or not One Man's Treasur
Willys41
Larry
Pleasanton Ca.
2020 Jeep Willys
What I see watching YouTube videos like Matt's off road and trailmater off road recover is the front axle U-joint fails and ether pops the ball joints out or brakes the aluminum knuckles no mater what size tires they are running.
I think RCV axle shafts would be in your case the only thing I would consider and maybe ball joints also.
Other components will ware out put in most cases wont brake.
