dstevens
CA
2024 JLURX
I'll post this information here in case someone else is crazy enough in reinvent the wheel like I did. And has the same skid.
Introduction
On my 2024 2.0T Wrangler Aux fuel tank I noticed that on the left side there was unused space running from the back of the transfer case to the rear axle between the drive shaft and the exhaust. I wanted more fuel range, so the space was perfect for an auxiliary fuel tank.
I was not the first to notice this space and think it could be used for an auxiliary fuel tank. Long Range America has a 17 gallon fuel tank for this space. The 'Long Ranger' has a 70 liter (18.5 gallons) tank. Roam had a 316 tank of 21 gallons but does not seem to be in business now.
Other options existed for auxiliary fuel tanks - the Titan tailgate mounted plastic tank which holds 12 gallons on the rear tailgate.
Why make my own? For clearance, weight and compatibility. The LRA and LR tank take great pains to point out that they hang down no lower than any part of the stock vehicle. However I had replaced some of the factory cross members and the factory fuel tank skid, gaining around 1.5" of additional ground clearance over a factory wrangler. So either of those two tanks would hang down 1.5" lower than anything else on the Jeep. Plus I always would count on additional ground clearance on the left side of the Jeep where the fuel tank was not. Also with my skid system the tanks would not be compatible with the tank mounting. And finally, the LRA and LR are both around 100 lbs dry, which is more than double what I thought they should weigh. And they required an additional skid plate to protect the tank if rock crawling, which further reduced ground clearance and increase weight.
They are numerous other options carrying spare fuel and it comes down to use case. For emergency fuel plastic or metal cans carried either externally, inside or on a roof rack are the best compromise between weight and cost but not the best for convenience of use and space and possibly weight up high. Titan makes a 12 gallon plastic tank that sits between the spare and tailgate and is good for cost and space but not good for convenience of use and I don't like the idea of another 100 lbs of weight on a 3' lever arm when bouncing around off road, plus rear vision is reduced.
For emergency use plastic or metal cans are the best bang for the buck but for anything which you want to use regularly a permanently mounted auxiliary tank with transfer pump is the best solution.
Design
Criteria
I selected 304 stainless for the tank, which may have been the wrong choice - time will tell. The commercial tanks all used aluminized mild steel, presumably for cost and fatigue resistance. I wanted something that would handle higher ethanol concentrations but in hindsight aluminum probably would have been the best choice, being cheaper, easier to weld and probably just as good for fatigue and crack propagation. In research there were a lot of scary stories from the marine industry about not using stainless for any fuel tank with regards to crevice corrosion but I determined that the conditions were different for my use and this should not be a problem. Two advantages of using 304 is that I could integrate the skid plate into the bottom of the tank and also the heatshield on the exhaust side of the tank. Even a thin piece of 304 with an air gap would be enough to stop the radiant heat from the exhaust heating the tank.
Laser cutting made using stainless very easy but I would have tried much harder to get all lap welds rather than some lap and some corner welds. Also the amount of argon used was outrageous - around a full tank, but there were no oxidation on the inside of the welds. I tried using solarflux, which worked well, but in the end just a lot of argon worked and I did not have to worry about the glass like solarflux residue clogging up the fuel pick up over time. I tried using copper backing blocks, which did not work.
Filling / Draining
As an auxiliary tank, the tank would till with the main tank and then fuel would transfer at will with the use of a transfer pump. The aux tank filler was T'd into the main tank filler tube and my theory was that the fuel running into the main tank would bypass the aux tank until the main tank was full, at which point the aux tank would fill up. In practice about the aux tank would end up just under half fill when the main tank filled so I just pump some of the fuel over.
EVAP / Emissions
Fairly simple. Keep everything as a closed system. Use the emissions rated plastic lined hose (I purchased a junk yard fuel tank hose set for this). In the end the only plumbing was 1) fuel pump suction to fuel pump to fuel filler tube. 2) Fuel level vent valve to a Tee in the stock FLVV. 3) Fuel filler tube T to aux tank. All closed systems.
Mounting
I establish that the front of the tank could sit on the support than ran behind the transfer case. The rear of the tank bolts to the frame cross member above the rear axle. Fairly simple.
Measurement. (No photos to show).
Solidworks modelling. Gross capacity 13 gallons usable capacity 11.8 gallons. Pump did not end up being mounted on back of tank. Above frame cross member was better.
Jeep Wrangler JL Auxiliary fuel tank DIY writeup tank-3d-33
Mock up out of plastic board.
Jeep Wrangler JL Auxiliary fuel tank DIY writeup 030
Laser cut parts. Baffles not shown.
Jeep Wrangler JL Auxiliary fuel tank DIY writeup 2023Dec%20060-12
A lot of welding.
Jeep Wrangler JL Auxiliary fuel tank DIY writeup 033-12
Testing for leaks
(no photos) Adapted a schrader valve and pressurized to 4 psi for a week. Also submerged in water for a bubble check.
Test fitment
Jeep Wrangler JL Auxiliary fuel tank DIY writeup 032-15
All installed
Jeep Wrangler JL Auxiliary fuel tank DIY writeup 031-15
Components
Fuel Sender
0-90 ohm floatless tubular level sensor. $110, Tanks Inc. Screws are #10-32
Fuel Gauge
The Apexus model PG200-b is a combination gauge and pump controller. Part PG-210 for the 0-90 ohm gauge. $90 from Australia.
Transfer Pump
Facet FEP304SV Posi-Flo $66 Amazon Catalog. Specifications. Mounting holes are 1/4" on 2-1/2" centers. Pumps roughly 1 gallon every few minutes.
Suction Tube
There are several marine suction tubes that work well. $21 Amazon. $21 Ebay. 1/4" npt female outlet, 3/8" npt male fitting.
FLVV
The fuel limit vent valve shuts off the vent air from the tank when filling in order to maintain an air gap in the tank. Attwood makes two marine versions which are suitable. The difference between the A and B part numbers is that the B part number has an extra vent line which we connected to the top of the front of the tank so that that part of the tank vents when filling.
$80 Attwood 99FLB080-1
Screws are #10-32
Fill Tube
Dorman 577-106 fuel filler neck $116 Amazon This is designed to replace a broken plastic fuel filler, but works well. It has a rollover valve at the bottom. The top barbed fitting is 32.25mm with a 36.1mm barb.
Conclusion
It works, but I ran out of time and energy to finish the project to my satisfaction. The aux tank provides around 10 gallons of fuel, less than the design capacity of 11.5 gallons. To fix this would require removing the tank, then filling with fuel using a measure and seeing when the FLVV shuts off the vent air, then diagnosing how much air space is left and if that is what it should be. To be fair the stock Wrangler fuel tank does the same thing - if I fill up at the pump the fuel gauge never gets to full and the gauge moves down in the first couple of miles.
The pickup is at the extreme left rear of the tank, so will pick up fuel when level or going up a slight hill, otherwise you're going to have to wait until conditions improve. Multiple pickups would help but the simple solution is that I start to pump fuel once the main tank gets down to about 3/4 full. This leads to the next point.
The stock fuel gauge uses a combination of the level sensor and consumption information from the PCM to show the fuel level. If does not like the sudden appearance of mystery fuel and this causes the fuel gauge to go up and down 1/8 of a tank at a time over a 5-10 minute period. The logic only wants to see the fuel level go up when the engine is off and then it resets as it thinks you have refilled. The solution is to pump small amounts of fuel regularly. It's not critical, but if you do this then the fuel gauge and estimated range seems to work correctly.
Final weight with tank, pump, hoses etc is 55 lbs empty.
It's all a trade off between cost, weight, ground clearance, convenience of filling, convenience of transfer, storage space both interior and exterior, accident risk. This solution is great for ground clearance, convenience of filling and transfer, storage space, accident risk, not too bad for weight but at the high end for cost. However my use when towing a trailer is that I use the aux tank every time I fill up with gas. For someone who hits a long trail once per year then two 5 gallon containers strapped to the rear bumper would be a good solution.
3d Files
Solidworks
Willys41
Larry
Pleasanton Ca.
2020 Jeep Willys
Introduction
Design
Criteria
Filling / Draining
EVAP / Emissions
Mounting
A lot of welding.
Test fitment
All installed
Components
Fuel Sender
Fuel Gauge
Transfer Pump
Suction Tube
FLVV
Screws are #10-32
Fill Tube
Conclusion
3d Files
Solidworks
Here is another option for an Aux fuel tank
I installed a muffler delete Borla muffler which now gave me an open space in the rear.
I chose to go with storage put a fuel tank can also go in its place with a transfer pump.
I also built a 3/8 aluminum skid plate.
Fuel capacity would be about 12 to 13 gallons.
Jeep Wrangler JL Auxiliary fuel tank DIY writeup REAR (2)
Jeep Wrangler JL Auxiliary fuel tank DIY writeup REAR (7)
Jeep Wrangler JL Auxiliary fuel tank DIY writeup REAR (8)
Jeep Wrangler JL Auxiliary fuel tank DIY writeup REAR (5)
Jeep Wrangler JL Auxiliary fuel tank DIY writeup REAR (1)
GATORB8
CLT NC
21 JLURe, 06 LJ, 25 HDZR2
Introduction
Design
Criteria
Filling / Draining
EVAP / Emissions
Mounting
A lot of welding.
Test fitment
All installed
Components
Fuel Sender
Fuel Gauge
Transfer Pump
Suction Tube
FLVV
Screws are #10-32
Fill Tube
Conclusion
3d Files
Solidworks
Wow! Thanks for sharing!
Just to add some other options. Motobilt replacement 21 gallon: https://motobilt.com/products/rear-...7wrrQD2UT854qGrRY1ttS0vYCWTJHR2BoCtZsQAvD_BwE
and AEV has one that sounds like the Titan (plastic tailgate mounted).
dstevens
dstevens
CA
2024 JLURX
I considered the tanks that mount behind the rear axle but felt that the compromises were too great for me - greater weight (100 lbs vs 55 lbs), rear sway bar must be removed and of course having to endure the engine noise from removing the rear muffler. And access to the filler tube would be more difficult. You could use the space under the Jeep for an extra muffler to get around the noise problem. Also note that the Motorbilt tank replaces the factory tank but a similar design could act as an auxiliary tank.
Slojo
Donald
Ft Myers
2008 JKU
The storage behind the axle is a good idea. I would not put a fuel tank back there, even with skid protection. The government and car manufacturers stopped that because ruptured fuel tanks from rear end collisions (and those seem to be the most common accidents) were a huge safety problem.
Willys41
Larry
Pleasanton Ca.
2020 Jeep Willys
You are right.
Rear gas tank should only be used for off road only.
roaniecowpony
Retired Engineer
I considered building a tank, since I have the resources of a friend's very capable shop. But in the end, I bought a side window gutter rotopax type of mount for a 4 gal Rotopax and I fabricated a mount for another 4 gal Rotopax that bolts to my Teraflex tire mount. I haven't used either of them and don't expect to get a lot of use from them, except for Dusy-Ershim trail.
Considering taking one on the Mojave run coming up.
Jeep Wrangler JL Auxiliary fuel tank DIY writeup 20241023_092653[1]
Jeep Wrangler JL Auxiliary fuel tank DIY writeup 20240917_160703
Jeep Wrangler JL Auxiliary fuel tank DIY writeup side rotopax
roaniecowpony
Retired Engineer
Ct_Formula
Orange Ct
2021 Rubicon JL, 2011 JK Sahara
Self Employed
Guys those are some awesome designs! Bravo I applaud you
THAW
Foster
23 JL4DrRubicon
A note on weight:
I have the LRA tank (which I love), and can tell you the tank itself is nowhere near 100 lbs. Unfortunately I don't have an exact weight, and can no longer easily weigh it since I installed it nearly a year ago. I had my tank stored for a few months before install and had to move it at least a dozen times, so can tell you it was more awkward than heavy and the tank alone felt like it was probably 50 lbs. I believe the 88 lb list weight on the LRA website is a rough shipping weight that includes packaging (though not the half pallet upon which mine arrived); the Australian site lists the weight under "shipping dimensions" as 90.4 lbs (41 kg).
Additional notes:
  • My dash gauge doesn't suffer the issues yours does; it responds slowly but steadily upward - slow because I believe the Jeep computes a time-based average from the stock sender unit float position (so the dash gauge doesn't fluctuate wildly due to pitch and roll).
  • My main tank fills completely before the aux, as the LRA has a type of flap valve on the filler T.
In any case, very impressive project, and I think your ground clearance justification is a very reasonable tradeoff for lower-than-LRA capacity.
dstevens
dstevens
CA
2024 JLURX
Thank you for the information about the LRA. If the ground clearance was high enough for rock crawling then I think it would be a winner.
After using mine for a longer period the fuel gauge issue does not ever seem to have repeated the odd behavior. I do tend to transfer the fuel as the main tank empties.
If I ever drop mine then I'll have to think about a flap in the filler Tee.
