On a 2019 2.0t I'm almost certain it cage with etorque so there are in fact 2 batteries. One is the massive 48v mounted underneath with its own skid plate as pictured above. You don't have an aux 12v battery...or an alternator. The belt start generator charges the 48v battery and the 12v battery is chaged by a DC to DC inverter. Literally takes 5 seconds to look underneath. If there is a skid plate on the drivers side behind the transfer case you have etorque.Thanx... Yes, the main 12v battery. AAA tested out the battery and charging system. The battery was definitely dead (9.8v). I need a more deep dive on the charging system. Agree on the possibility of parasitic draws. I've added a light bar, an RV tow package, and an auxiliary braking system. Front/rear dash cams are both switched.
Interesting the many responses on the lack of the auxiliary battery. I am the original owner, bought new from a dealer in Tustin CA. I am absolutely certain this vehicle came from the factory with only one battery.
Well my bet it does not have an alternator and it’s a etorque. I have a etorque v6 no issuesThanx... Yes, the main 12v battery. AAA tested out the battery and charging system. The battery was definitely dead (9.8v). I need a more deep dive on the charging system. Agree on the possibility of parasitic draws. I've added a light bar, an RV tow package, and an auxiliary braking system. Front/rear dash cams are both switched.
Wouldn’t that violate the emissions standards that Jeep has certified to?Not all jeeps have 2 batteries.. there are some that only have the 1 main battery
I was wondering about that too. Especially when disconnecting the S/S systems.Wouldn’t that violate the emissions standards that Jeep has certified to?
No clue.. I personally know 5 people with 1.. from what another person said.. it appears to have happened during the supply shortage during Covid.. but I know for certain some jeeps only have 1Wouldn’t that violate the emissions standards that Jeep has certified to?
I have a 2018 JL with 2.0 and etorque that only has the one battery. Aux battery box is empty with no wires. Have had my local mechanic that I’ve used for years go over it while on lift. No extra battery.2019 Rubicon JL, 12,000 miles, 2 L Turbo 4
I was getting error messages pertaining to auxiliary switches unavailable, and have replaced the chassis battery 3 times.
Dealer told me it was the auxiliary battery.
I took it to my local repair guy who dropped the fender liner and pulled the auxiliary battery case. It was empty! No cables, nothing. Case looked like a battery was never there.
Any advice here? Everything is saw online indicated that auxiliary battery was under the fuse block, accessible thru the fender liner.
Bizarre. Help?
I’m including either the 12 volt secondary/auxillary battery in the passenger fender area or the 48 volt etorque battery under the Jeep as being the two general options I am aware of. Not saying anyone is wrong when they say they have neither, just that I had never heard of it. I learned something new. Do 392s have only have the one main battery in the engine compartment?I have a 2018 JL with 2.0 and etorque that only has the one battery. Aux battery box is empty with no wires. Have had my local mechanic that I’ve used for years go over it while on lift. No extra battery.
Thinking about it, without the aux, the start stop will still work…Wouldn’t that violate the emissions standards that Jeep has certified to?
Not anymore, haha.Wouldn’t that violate the emissions standards that Jeep has certified to?
That is a great site! Thanks!First things first…
Enter here:
https://fcagroup.my.site.com/RAM/s/equipment-listing
Run your vin number to know your jeep equipment and other things…
Yes. And no ESS at all.Do 392s have only have the one main battery in the engine compartment?
