Chamlin2
- Curtis
- Dec 31, 2019
- Erath,Louisiana
- 2018 JLUR ,2001 TJ, 1978 CJ5
- Occupation
- Deep Sea Diver
so this is isn't related to the tuner butwell It showed up this morning in uconnect. But now need to see why the switches don’t have power.
I recently installed the Mopar Aux switch on our 2018 JLUR 2.0L
Installed everything as per instructions and was a fairly simple install plenty out there on videos and guides as the Mopar instructions kinda suck. worst part was switching the pins on the Body Wiring harness.
Once installed and batteries were reconnected and started.... Boom I get a C.E.L, and informed that Start/Stop unavailable.
Well I knew I needed to get it flashed by the dealer anyway for the Aux switch to work ... so I brought it in to have them figure out what was going on. After hours of the tech scratching his head and me telling him where some things are at, swapping out the I.B.S (intelligent battery sensor on the ground) they disconnect the Aux switch system and say they think the switch is bad as its back feeding voltage through the (orange) Can Bus wire. so after paying the dealer with my first born I'm still don't have a working Aux switch.
they said they were getting 11.4v through the Can Bus wires
I pulled apart every connector all wiring was correct. So with the Orange Can Bus wire disconnected its only putting out 3.4v I can replace the switch itself for about $40 I guess that cheeps insurance but just wanted to see if anyone had any issues as well?
