Aux delete- Start/Stop still charging
Mguy
Far Away
2020 JLUR 6spd MT
A healthy 12V automotive battery should have a resting voltage no lower than 12.3V
This statement is not correct for AGMs. A fully charged AGM showing a 12.3 resting voltage may start a Jeep, but it is on it's way out. It likely has trouble holding that charge. After a few more days resting, it is probably at measurably less voltage.
Heimkehr
Pennsylvania
2021 JLU 2.0T
You'll want to flesh that out a bit more. What target voltage figure are you proposing?
By way of example, the original Yuasa AGM in my 2015 motorcycle continues to reliably crank the engine, with resting voltage trends that hover at or just above 12.3V during the riding season (i.e., absent the tender that I use during seasonal winter storage.)
garyji
Gary
Western NC
2017 JK Sahara, 2021 JLU Willys
You need a new main battery. Don't cheap out, and make sure you put in an H-7.
G.
Devildoc22
Zac
2020 JLU Sport S
I went to Costco and put in a new H7. Started getting worried because the “charging” message was still showing. After 15 minutes of driving, the ESS kicked in and everything was fine. Thank you all so much!!!
Dan18jl
Daniel rincon
Jeep jl rubicon unlimited
Hi, I deleted my auxiliary battery from my 2018 jl rubicon. I electrical taped the positive auxiliary line, & connected the negative auxiliary line, to the new negative side on main battery. The new battery replacement I put is an optima yellow top H7. I upgrade to a bigger one.
No dash lights popping up, But when I check on my voltage on my dash, it reads 12.3 & goes up & down on voltage. & has me a bit worried. Is this normal on the bigger battery?
Terrymo
Terry
2023 JLURXR 3.6 ET
With the engine running the voltage on the dash will show the output of your alternator. It varies based on what is asked of the alternator by the electrical system including charging your battery. With the engine off, it will give an imprecise measurement of your battery voltage. If your battery has been fully charged with a reputable charger, testing the battery itself with a multimeter and seeing 12.3 volts would be an issue.
Dan18jl
Daniel rincon
Oh okay thank you terry I should recheck my battery & alternator.
cause when Im driving around it shows 12.8 & when I start breaking coming to a stop, it shoots back up to 14.5 & back to 12.8 when stopped.
Terrymo
Terry
2023 JLURXR 3.6 ET
The voltage varying that much as you describe seems unusual to me but I’m not an expert, Hopefully others like @THAW have some input.
Dan18jl
Daniel rincon
No worries it’s all good, i still appreciate the help thank you!
THAW
Foster
23 JL4DrRubicon
@Dan18jl
Neither 12.8V nor 14.5V alone while driving is cause for concern, and it's normal for voltage to increase by a volt or so while coasting (or decrease similarly while turning the steering wheel sharply at low speed). But, your voltage swing does seem rather large.
I really don't have any advice other than, if you're concerned about the battery, do the standard multimeter voltage check and/or a load test. Though I would think your JL mostly sitting at 12.8V while underway is an indication the JL sees the battery as healthy and charged.
Dan18jl
Daniel rincon
@Dan18jl
Neither 12.8V nor 14.5V alone while driving is cause for concern, and it's normal for voltage to increase by a volt or so while coasting (or decrease similarly while turning the steering wheel sharply at low speed). But, your swing does seem rather large.
I really don't have any advice other than to do the standard multimeter voltage check and/or a load test, though I would think your JL mostly sitting at 12.8V while underway is an indication the JL sees the battery as healthy and charged.
I will sure check up on that also, thank you for the advise thaw, that put me at ease.
