Automatic shifter assembly failure
Fergshouse
Tennessee, USA
2020 Sahara North Edition
I have a 2020 Sahara JLU that I bought Dec 2023 with just under 5,000 miles (it was a lease vehicle in pristine condition). I have the 2.0 turbo e-torque engine and automatic transmission. The other day when it was cold, after I started it the PRNDL lights were flashing and it would no go out of park. It took 7 or 8 restarts before it would go out of park and then the CEL was in. Drive it home and took it into the CDJR dealership the next day.
After diagnosing, they said the whole shifter mechanism needs to be replaced. Of course it is out of the basic 3/36 warranty and they said the shifter is not covered under the powertrain warranty as it is not technically part of the powertrain. The other bad news is they said it will be Jan 6th before the parts are in and total cost will be over $1400.
Has anybody else had this happen? Looking through other threads I saw a few mention shifter problems, but not sure how wide spread of an issue this really is. I guess I’m just bitchin’ about it, but definitely not real happy.
Phrank
NEPA
2018 JLUS
What codes did it throw?
My Jeep did the exact same thing when the canbus failed. A battery issue would also cause this. A canbus or battery failure would generally have other symptoms, but not necessarily. Before you throw out the big bucks for a shifter assembly, you definitely want to eliminate the cheaper/simpler potential causes.
alphawolff
california
2021 JLU
The PDRNL lighting up indicates can bus failure. While I have seem the ESM fail on these, it is much more likely to be the connector at the r/f fender liner having connection issues. It is very common. There's multiple threads with write ups on how to fix it.
The DTCs can be checked to see what modules are losing communication. If it's the TCM primarily then it's definitely the connector.
It could also be the can-bus connector, but seriously unlikely on a 2021. That's a 2018/19 MY issue
Phrank
NEPA
2018 JLUS
I don't want to derail OP's thread, but I'm curious as to why it's more prevalent in the early years - did they use a higher quality canbus in later models, or is it that the part degrades over time meaning that the probability of failure increases with age?
alphawolff
california
2021 JLU
I'm not sure. I have replaced nearly 100 on 2017 Pacificas at this point. Very common on for that year and it's the same part used for the JLs. You can literally smack the glovebox area of the dash and everything comes back online. I'd suspect it's a combination of material and age related oxidation.
Fergshouse
Fergshouse
Tennessee, USA
Thank you all for the quick responses. The jeep is still at the dealership, but I’m planning to get it back instead of keeping it there waiting for parts. Will check the things you guys mentioned and post back what I found.
Fergshouse
Fergshouse
Tennessee, USA
So, unfortunately it looks to be the shifter assembly. The batteries load test fins and could not find anything with the canbus system. Nothing loose and no loose fuses. Looks like I’ll move forward with the shifter replacement. Thanks again for the input!
ImLostAgain
Richard
Oregon, USA
2019 JLUR
Forgive me if a Newb question. You are speaking of the 'star connector', green behind the glove box? My understanding is these are just CANBus hubs - similar to old networking hubs that just repeated messages to all connected devices. I *might* be looking at an issue with this part and based on your comments it is not unusual to have issues with it over time? I have a 19 JLU
alphawolff
california
2021 JLU
I am indeed speaking of that connector. They're called star connectors internally in our parts system. They are indeed just hubs, but they're important in that they each contain a 120 ohm resistor required for can-c communication. There's two per network, 120 each for 60 overall. In vehicles without them the resistors are internal to some module instead
Honestly I have no idea what goes wrong with them, maybe internal corrosion or something. Bad solders? I've never broken one day to see if I can determine the cause, but they're a common issue from 2017-2019 or so. 2017s (pacificas) especially.
ImLostAgain
Richard
Oregon, USA
2019 JLUR
Thank you for the quick reply. From what I have read, it seems those parts do fail and can cause random, intermittent CAN - C comms issues. From you comments, MY 18 and 19 seem to see this?
I was a computer hardware technician in a past life (Apple computer in R&D) so have some skill in diagnosis. Not a huge fan of throwing parts at things, and if low cost and low risk with known issues, then it is not always a bad thing :).
alphawolff
california
2021 JLU
They're cheap and easy to replace. Generally if I see one from those years come in with 70+ can DTCs I just immediately replace it without giving it a second thought. If the issues return we can go down that rabbit hole
ImLostAgain
Richard
Oregon, USA
2019 JLUR
Thank you for all the info! It is greatly useful and appreciated.
ImLostAgain
Richard
Oregon, USA
2019 JLUR
Hey thanks again for the great info! I ended up having comms issues that were causing loss of power steering, and tons of codes (only off road, of course), mostly loss of communication on the CAN-C bus. I had a 'certified used jeep' warranty so took it in and the dealer diagnosed it as a bad star connector and repaired a couple of other connectors they had concerns with. I believe they also checked the interconnect you referenced in an earlier post. All better now with no recurrences of the issue for me.
I was gathering information in case I had to diagnose and fix myself. You were spot on! Thank you for helping everyone out on this forum with your knowledge and experience.
Vicrider
Oklahoma
2020 Wrangler Sport
Did you get this resolved ?
