Howard crusoe
Can you replace the the jeep logo on the auto shift for a custom one ?
I want to know this too. I want to replace both inserts.Can you replace the the jeep logo on the auto shift for a custom one ?
Yes, all you have to do is gently pry the center Willy’s emblem out. The auto shifter emblem is 39mm. I replaced mine with a Veteran Coin. Used doubled sided tape and it fits in perfectly!!I want to know this too. I want to replace both inserts.
Wow! That looks really really good. I’ll have to find something that size.Yes, all you have to do is gently pry the center Willy’s emblem out. The auto shifter emblem is 39mm. I replaced mine with a Veteran Coin. Used doubled sided tape and it fits in perfectly!!
How do you do this?Some Mando, beskar bling.
Carefully pry insert out from bottom center, it will lift out, no adhesive used.How do you do this?
