Auto Stop/Start Eliminator
Rustynail11
Mansfield, TX
2022 Wrangler JLU Rubicon
Do you still need to disconnect the negative cable form the Aux battery and pull fuse 42 if you install the Auto Stop/Start Eliminator?
Maverick909
I.E.
www.instagram.com
or get the gensis dual battery kit :D
Heimkehr
Pennsylvania
2021 JLU 2.0T
Think of disabling ESS as a two-step procedure:
1. Isolating the ESS battery, via disconnecting the related Negative cable and removing Fuse F42. Doing so will prevent that battery from eventually cannibalizing the vehicle's main 12V battery. However, this won't prevent ESS from functioning; so long as it isn't turned off, restarts will pivot to the main battery for power.
2. Using a defeat device, like the Auto Start/Stop Eliminator, creates a memory function. If the driver turns ESS off, the harness will remember that setting after the vehicle is shut down and restarted.
Terrymo
Terry
2023 JLURXR 3.6 ET
You were able to say in a few sentences what it takes some folks an entire blog worth of words to say. 👍
AndySpill
Andy
Pittsburgh
2018 JL Sahara
If you have decided to turn off ESS events from happening there is in my opinion nothing but advantage to disconnecting the ESS/Aux battery and pulling the aforementioned Fuse to prevent it from being isolated.
The ever so slight advantage of keeping it connected, in additional battery power, is enormously outweighed, I think, by the potential for this battery to not only go bad, but in so doing risk taking the main battery out with if in remains connected.
It serves little purpose but to keep appliances running during the very ESS events you've chosen to bypass.
AndySpill
Andy
Pittsburgh
2018 JL Sahara
Yep, that's me Terry, and its because, with complete deference to James' post above, I don't just explain what to do but why to do it.
That takes words the inexperienced often appreciate, and they, along with the experienced aren't forced to read.:)
THAW
Foster
23 JL4DrRubicon
Jeep Wrangler JL Auto Stop/Start Eliminator 1000003968
Terrymo
Terry
2023 JLURXR 3.6 ET
You flatter yourself by thinking I’m thinking of you I guess. That’s not the case, but you do you boo.🤓
AndySpill
Andy
Pittsburgh
2018 JL Sahara
Terry, if you want to open your mouth and complain about wordy posts you aren't forced to read, irrespective of whether or not you are referring to me, if your complaint describes me, I consider it fair game to explain why I/some, use those words: which paradoxically enough IS to explain.
I trust that if you want to complain that you can be a big boy when someone complains back.
And, just for the record, who exactly were you referring to here, as it clearly wasn't me. Perhaps you have a point.
I won't hold my breath waiting for your links, or out of legitimate words to explain himself, @THAW Foster's memes.
Terrymo
Terry
2023 JLURXR 3.6 ET
LOL you’re like the girl at a party that thinks all the other girls are talking about her when they’re not. If it makes you feel better, I meant it as a compliment to @Heimkehr who is clear and concise and easy for me to follow. If my teasing from time to time hurts your feelings I apologize. You will see I try to give at least equal time to laughing at myself.
