Auto park dissengaged
MyDaughters20JL
WA
20 JL Sport S
Maybe I’m here for some REAL technical answers not dumb ones
maybe if you learn to relax and not come off as a tool when someone makes a joke, you'd get better responses, but hey, whatever floats your boat
  • Love
Reactions: GtX
Redbaron73
Ronnie
2020 sport s unlimited;2020 Rubicon Unlimited
Unplug the door from harness, connect seat belt, and try again. This will eliminate all of the conditions that could cause the failure.
Rhinebeck01
Ormond Beach, Florida
Retired at 55 ..
@Johnnyrotton
I know this issue is frustrating... Wise ass comments to you don't help any.
I encourage you to just ignore the off the wall Facebook group type comments..
As I mentioned this may need troubleshooting by a dealership Tech, since you say it just started to happen and continues to be an issue.
Consider, before taking to the dealership, carefully unhooking the driver's side door harness and then plugging it back in very carefully. Do this say 3 times in a row.. See if doing this has a positive impact.... corrects the issue.
Could be a contact issue....moisture or whatever in regard to the door harness connection that is causing the JL to not recognize the door so to speak.
Rhinebeck01
Retired at 55 ..
@redbaron
@Johnnyrotton
Was typing my wordy reply to the OP, when you posted your reply.
You see as I do ... I mentioned earlier in this thread, that it could be door harness connection related.
Hopefully, the OP will do as we both have suggested and focus a bit on the door harness. If that doesn't get it done by then he'll need dealership Tech to test...to remedy.
Mtpockets
MT
Massachusetts
2021 Rubicon 4-Door
I forgot to fasten my seatbelt once and the chime reminder wouldn’t stop ringing until I belted up.
My F350 does the same.
At what point does the chime reminder drive you nuts or does it eventually stop?
Johnnyrotton
Pennsylvania
2018 Jeep Wrangler rubicon jl
@Johnnyrotton
It’s just the driver side door that will affect this correct
Rhinebeck01
Retired at 55 ..
@Johnnyrotton
Carefully unhooking the driver's side door harness and then plugging it back in very carefully. Do this say 3 times in a row.. See if doing this has a positive impact.... corrects the issue.
Could be a contact issue....moisture or whatever in regard to the driver's side door harness connection that is causing the JL to not recognize the door so to speak.
Johnnyrotton
Pennsylvania
That’s what I don’t understand the door shut I just went out shut the door put my seatbelt on first put my foot on the brake pedal. Start my vehicle up I put it in the drive and it automatically shipped it it’s self to park in the message auto park engaged came on. I’m also getting a start stop warning light
Johnnyrotton
Pennsylvania
@Johnnyrotton
Ok I will try that in a minute. If not it’s gonna go to the dealer. Maybe there’s a software problem
Gummiente62
The Great White North
gummiente62.blogspot.com
18 JL Sport, 97 C5 Corvette, 03 HD FXD
I second the advice to examine and reinstall the dvr side door harness, as a bent pin on mine caused the exact same fault as what the OP is experiencing. If that does not help then a trip to the dealer is the only way to fix the issue.
FYI, if you're ever stuck and have to winch yourself out while standing outside the Jeep with a remote control, have the Jeep in neutral AND buckle the dvr seatbelt or it will auto park and you'll end up digging a 20' set of ruts with the rear wheels. Don't ask how I know this.
