Jteakus
- John
- Apr 18, 2020
- Oil City Louisiana
- 2020 Ecodiesel Unlimited Rubicon
Yeah. Rather sell the stockers now when I can still get money for them. W/ Tazer adapter, you can actually use your factory locker switches now even with the Currie axles (assuming you go e-locker of course).
Only issue I'm running into is Currie's site doesn't list anything below 4.88 and I don't want a 9" -- so will call and see if they offer 4.30 or 4.56. I'm pretty sure 4.56 will be ok for 37" daily use but gotta run the math (concerned about 8th gear RPM @ 70 mph).
Daily use = 37" KO2's on AEV Ram HD Katla wheels (ride quality, noise, snow performance)
Dedicated wheeling trips = 42" MTs (looking at treps, new trail grappler, or crawlers) on 20" forged beadlocks (not sure which wheel I'll go with yet, but has to be forged).
Will likely run a fender chop kit as I don't think 3 1/2" of lift will clear 42's otherwise. Buddy of mine put 39's with that and there's room for days with the same lift. I'm running Fox's new 3.0's internal bypass shocks w/ adjusters front and rear with air bumps, the shocks are for 3-5" of lift, so even if I have to increase a bit should be good.
edit: Currie confirms I can do 4.30 and 4.56's. So now have to decide.
[/QUOTE
Whenever I'm in a gear situation like you are I always go with the deeper gears and rarely regret it.
For everyone here considering gear changes here's an easy calculator. Remember, bigger tires are also heavier and a little deeper gear helps get the mass rolling. You might look at a 4.88
https://www.intercotire.com/tire_size_change_gear_ratio_calculator
