Another CB/GMRS question
Taxman
Alex
Raleigh, NC
1985 CJ-7, 2018 JLUR
CPA
I currently have a Uniden CB and 4’ Firestik mounted to a bracket on the spare tire carrier. It has a grounding strap and I get great reception as far as CB is concerned.
I have a handheld GMRS but I’m looking to get another unit installed to be able to communicate with other groups that are using GMRS on trails.
Does anyone know if I can use the same antenna cable that I am using for my Firestik for a GMRS antenna?
I’m looking to get a low profile antenna like the Laird Phantom Series models.
jeepdriver99
JD
Central Ohio
18 JLR 2 Door, 21 JLU TD, 06 GC, 54 Willys SW
Retired, W8BWD
You should be able to use the same cable but not the same antenna. That is as long as you have the same connectors on each radio and antenna.
Taxman
Taxman
Alex
Raleigh, NC
CPA
Yes, I know I need a different antenna, but wanted to know about cable. I can always get adapters for both ends, I was just trying to avoid having to run another cable. I may end up running both the CB and GMRS in which case I'll need both anyways...
Thanks.
