an empty dashboard
Alexsandr1992
Александр
rossia
Jeep Wrangler jl 2.0 rubikon
Jeep Wrangler JL an empty dashboard 1000099727
Good afternoon. help me determine the cause of this condition
Alexsandr1992
Александр
rossia
the menu is empty.
My problem is not permanent.
DaltonGang
Doesn't Play Well With Others
Alexsandr1992
Александр
rossia
Bob Burd
Bob
San Jose, CA
www.snwburd.com
It's not the battery or fuses. Mine does this occasionally, usually cycling through menu restores it. Never permanent. A quirk of the older models, I think. Mine is a 2018. There's a TSB to update the display, but I never cared enough to get it done since it's a very minor issue. There are other weird things like displaying 800F and 99999999 on the odometer. I believe the problem occurs at startup when the display gets erroneous data via the CANBUS.
Ramboy
2025 Wrangler Rubicon
I’ve seen these issues discussed on this forum before but personally, if it’s still under warranty I would take it to your dealer to have it fixed. That way, the problem/fix will be documented. Good luck and happy Jeeping!
DaltonGang
tell me, what will it allow me? all the regular equipment will work?
How many Jeep Dealerships do they have in Russia? Any near where you live? That is where you are, aren't you?
DaltonGang
