American Adventure Lab Quick Release Inner Fender
jellis4148
Missouri
Does anyone have a Rubicon with the AAL Quick release inner fenders using there stock inner fender cut down? I’m extremely interested in these, but would like to see if they work with the factory inner fender cut down to fit. Also, in the picture on the website it looks like one of the mounting brackets runs the regular fender between it and the body. Thanks for the help.
Xtremetj
Greg
2019 F350 Platinum, Ignot Silver, 2019 Rubicon Unlimited, Billet Silver
Oil & Gas Environmental Rep
They will work. Seen several that have installed the light kit and not split the fenders.
DarkAardvark
2000 TJ, 2021 JLR
Do the stock fenders still suck on the 2020s and 2021s? As in fall down, rub on the wheels, etc. Or was that fixed?
jellis4148
jellis4148
Missouri
First I've heard of it. Link?
I’ve had no issues with my stick fender or inner fender. I mean, they aren’t great, but the do the job. For extreme off road, they need to be changed.
jellis4148
jellis4148
Missouri
They do rub on full flex with other tires. I never had them rub when I was stock though. I really want the AAL quick release. I saw them in pigeon Forge.
jdubya421
Jakob
Greensboro, NC
2020 Rubicon 2-Door MT V6
I am confused by what you mean by running the AAL inner fender AND the stock inner fender. The AAL will replace the stock one and not sure what you mean by using them together?
jellis4148
jellis4148
Missouri
The AAL fender only goes up to so far. You have to cut the factory inner fender to just under the stock fender. Keeps the mud out of it.
jdubya421
Jakob
Greensboro, NC
Seems like you just use the AAL inner fender. Same with the Artec ones I bought, should be fine even with mud
jdubya421
Jakob
Greensboro, NC
I did the AAL highline leds, front and rear inner fenders, and retention hardware all around. Great parts!
Jeep Wrangler JL American Adventure Lab Quick Release Inner Fender 20200827_085921
Looks good, I have the AAL lights and got artec inner liners. I should have done the AAL liners because they can pre cut for the falcon shocks and the install is nicer.
Headbarcode
LI, New York
2019 JLUR Stingray 2.0 turbo
Thanks. I believe AAL was the first company to offer liners designed specifically for chopped factory fenders.
Xtremetj
Greg
Just be aware that if you go to a big enough tire and have to start trimming in the rear... they won’t work. The mounting bracket will still mount but since the the bracket is following the original body line it be rubbing on it.
I learned the hard way and am now trying to sell both the front and the rear set. I switched to Nemesis.
Bocephus
Virginia
Sam’s Decorative Automotive Button Emporium
I’ve wondered about that. What lift kit and how many inches, and what tire size?
Xtremetj
Greg
Im running the 3.5 MetalCloak GameChanger with 1” spacers on 40” Nitto’s. Had to add the spacers when I went to the UD 60’s. They use a JK spring seat which is an inch lower that the JL so I lost an inch. Hopefully MetalCloak will release their 4.5” spring soon.
