LukeDagny
- Apr 20, 2024
- Central PA
- 2021 JLUR
I installed a 2" lift and had an alignment done on my JLUR. A picture of the alignment results are below. The only changes made during the alignment was to toe in. After the alignment my Jeep OK, but seemed a little twitchy. It also drifted to the right, if I took my hand off the wheel. After 3-4 car lengths it would head towards the berm of the road. I assumed this was caused by the crown of the road.
After some research and reading multiple threads, I figured I should add more caster. To address the drifting, I should make the passenger side caster slightly greater than the driver's side .
I have adjustable upper front control arms, and assume every revolution of the rod end, making it shorter, will add 1 degree of caster. From the 4.7 degrees measured at the alignment shop, I added 1 degree to the drivers side (5.7) and 1 1/2 degrees to the passenger side (6.2).
The twitchiness is gone, but it pulls to the right as soon as I take my hand off the wheel.
More caster on the passenger side made the pull worse, but this seems to go against everything I've read. Any suggestions before I take it back to the alignment shop?
