Algae in the washer fluid?
mixdup
Atlanta
2024 Unlimited Rubicon
I’ve got a 22 4xe that is still barely under factory 3/36000 warranty and I have the molar maximum care that is supposed to cover everything. The front windshield washer stopped working and I took it to the dealer who is claiming algae is clogging it and they want me to pay $400 to flush it
does this sound right? I didn’t put the algae in there or design a system to grow it. Has anyone else dealt with this?
if this is legit, anyone know how hard it is to take off the reservoir and flush the lines?
DUCK01
2023 JLU Sport, 2024 JL Sport
Are you refilling with washer fluid or just straight water?
mixdup
Atlanta
I’ve only put washer fluid in, but I’ve since found a video showing how to disassemble and it doesn’t seem too bad. Also the maximum care contract does seem to say it only covers defects in manufacturing or workmanship so this isn’t a part failure
MayThe4x4BWU
Sam
Bartlett, IL
2023 JLURXR
LFG 😅
People have complained about rain-x bug remover causing clogs. I use the cheapest blue stuff from Walmart and Home Depot and have never had an issue. Krystal Kleer
Same. Funny how sometimes the cheapest, simple stuff, is the best stuff for vehicles 😁
I always use a simple textured sponge, bucket of hot water and some Bugs N' All to get rid of the bugs on the windshield and front grille every few days. Otherwise, I just wait til heavy storms and use mother nature to wash the windshield off along with a free car wash 😅
DaltonGang
Doesn't Play Well With Others
Do it yourself. Hook a low pressure air hose from a small compressor, to your washer lines from your hood. The blow air through it, a little at a time. Then, shove your garden hose in the reservoir, with a spray attachment, and spray the crap out of the inside. Let it overflow for a minute or two, to get the crud out. I would add some bleach inside, a teaspoon or two, and let it sit overnight, then flush the fluid out. Oh, don't use well water, unless you add some stuff to prevent algae.
X35
PA
2025 Wrangler Willys XR
How the hell does algae grow in washer fluid that has methanol in it 🤷🏻‍♂️ I’ve never had a problem with anything growing in the cheap blue washer fluid 😳
Ratbert
PNW
2022 AEV JL370 JLURD
Software Engineer
Excellent question. I'm pretty sure it needs quite a bit of light too.
Go4Low
Jorel
2020 JLUR
Flip
Johnny
Virginia
2023 Jeep Wrangler Sport
Retired Power Plant Engineer
Put some bleach in there, pay your kid a few bucks to sit there and squirt all of the washer fluid out until the reservoir is empty. Fill it up with some cheap washer fluid. Good as new. 👍
dragoneggs
Seabeck, WA
'22 Snazzberry Pearl JLR
RNAR... Red Neck Auto Repair at its finest. Sound it out... it gets better.
AFD
Northeastern US
2023 JL Rubicon (2DR/V6)
Yes, whatever's in the orange Rain-X bug remover solution definitely likes to separate into a bit of sediment over time and unless you're using it every single day, it'll eventually start to give you a few seconds of dry/nothing spray until it gets going.
Hasn't really been much of a problem for me, since I use it at the end of every day with my fancy Scrubblade dual-vane textured wipers.. and then still have to grab a paper towel and scrub away the damn bugs by hand. Kinda wishing I hadn't bought a few more jugs, since that shit really isn't any better at removing bugs or repelling rain compared to the cheaper -20°F blue stuff.
Wbino
NJ
Have a pool? Put some chlorine tablets in it. 🙃
au176
WNY
2021 Islander, 2020 Newmar Ventana, 2014 HD Road King
Tired again
Especially when you sit and watch your kid do the work!
mixdup
Atlanta
I just got the Jeep back today, it was also there for the 95B 4xe recall so they had it for an extra day until they confirmed the battery checked out
I've got plans the rest of the weekend, but I will dig into it Monday since it's a day off work. It may not actually be algae, it may be something else. I doubt the tech at my rural Georgia Jeep dealer is a biologist on the side.
I actually do think I put in the RainX stuff someone mentioned above, I honestly don't remember though because it's been clogged so long and I've just been putting off doing anything about it
The tips everyone provided were great, I am pretty handy, dad was a mechanic so I'm not inept here, but since it was under warranty I was going to have Jeep do it.
