AGM BATTERY CHARGING
Big Juan
Juan
Santa Rosa ca
2018 Rubicon
Going to swap out stock battrery for an AGM type battery like the optima DH7. WII’ll my alternator charge the battery ok or do I need to do some type of upgrade? I have a 2018 Rubicon 3.6L.
thanks.
Tr4ckD4ys
NY
2025 Jeep Wrangler Rubicon Xtreme 35-inch 2-door, '41 Green
Tech
BDinTX
Dallas, Tx
Our 2021 EcoDiesel has an AGM battery while the 2020 eTorque has a sealed lead acid main battery.
It didn’t come as a surprise since there are a few other differences I’ve noticed, but I have always wondered if the charging approach was modified to support the different battery technology.
Now I’m wondering if ‘20 originally came with a AGM and the service department changed types when they warrantied the battery. It’s been in there since probably 2022, maybe ‘23… Guess I should consider changing it…
AndySpill
Andy
Pittsburgh
2018 JL Sahara
thanks.
I agree that this swap is perfectly fine as you are replacing your existing (AGM) battery with one of identical chemistry.
If you are upgrading to a larger (H7) battery from H6 you will need to remove a cleat in the bottom of the battery tray to accommodate the H7 battery.
What is the status of your Aux battery? Do you have one connected in your 2018? If so, best practices would have you bypass it or replace it as well at the same time you install the Optima.
VKSheridan
Vince
Broken Arrow, OK
2020 2 Dr Rubicon JL Hardtop
……. Now I’m wondering if ‘20 originally came with a AGM and the service department changed types when they warrantied the battery. It’s been in there since probably 2022, maybe ‘23… Guess I should consider changing it…
If it helps, my 2020 JL (2.0T) was equipped from factory with an AGM battery.
BDinTX
Dallas, Tx
Perfect thank you. I think I’ll probably go with an AGM. As it turns out, this morning remote start didn’t work for my wife and the aux switches unavailable message came up. Will probably be doing it this week.
garyji
Gary
Western NC
2017 JK Sahara, 2021 JLU Willys
Just put it in. You'll be fine.
G.
Jeep Wrangler JL AGM BATTERY CHARGING IMG_3783
