THAW
- Foster
- Oct 28, 2022
- PNW - prefer Middle of Nowhere
- 23 JL4DrRubicon
I assume the Innova 5610 does meaningful testing on some systems, but based on what I've seen of it I'm highly skeptical it is properly assessing your alternator. I believe it doesn't work well with smart alternators, and could have given you a false positive for failure.Correct. It’s plugged into the OBD port. I don’t know where it pulls it’s data from, but the analytical process takes quite a while. Since I don’t understand how automotive computers work, I’m skeptical. On the other hand, the new batteries need to be plugged in most of the time, even when the jeep is driven 30 to 40 minutes three or four days per week, although there is very little parasitic drain (mostly from the Genesis relay, I think).
The Innova 5610 has to be set up to read each vehicle. If it’s set up for, say, a Ford truck, then plugged into the Jeep OBD port, it won’t be able to connect, because it's speaking a different language or looking for different readings. When you properly enter year, make, and model, it asks which engine you have — so it “knew“ it was connected to a 2019 Wrangler with the 3.6, and it cycled through all the vehicle system checks. Maybe it’s just a light show?
I think I’ll give the guys at Genesis a call. I had hoped to upgrade to their new top plate, as the new system has almost zero parasitic drain, but it’s $500, bringing the total genesis and battery cost to about $2100… There is no discount for folks who have been suffering with the original Genesis system for years. (I was hoping there might be a $200 or $250 rebate for returning the old top. They’d still probably be making $150 or $200 on the sale. No such luck, so I’m reluctant to bend over and grab my ankles.)![]()
JScan is the best DIY way to properly assess the alternator.
A possible option for Genesis gen2 hub replacement: https://www.renogy.com/products/renogy-12v-24v-ip67-50a-dc-dc-battery-charger-with-mppt. It would take some wiring and app configuration.
