Yes they doDoes the sport have a 6 pin connector from the body to the fender?
I may be confused but do the white fender lights light up when driving with the headlights off? They come on when i use remote start and work correctly when i turn the head lights on. I have a 7 inch screen and don't see the DRLs in the UConnect settings. Is this a 8 inch screen thing only?So long as the sport fender wiring harness matches this
https://www.jlwranglerforums.com/JL-Wiring-Diagrams/LAMP-DRL-LEFT-BASE-connector-details.pdf
then all you need to do is set DRL type to "USA" and set location as "dedicated". Also if they were LED equipped fenders, set front turns to LED (though this may not be necessary, it isn't quite clear).
Edit: Oh, also, go into your UConnect settings after doing the above, and turn on DRL in the lighting options.
Have you enabled drl with a programmer? Yes they should be on when the headlights are off.I may be confused but do the white fender lights light up when driving with the headlights off? They come on when i use remote start and work correctly when i turn the head lights on. I have a 7 inch screen and don't see the DRLs in the UConnect settings. Is this a 8 inch screen thing only?
It is set to USA, Dedicated, LED front turn.Have you enabled drl with a programmer? Yes they should be on when the headlights are off.
Because that's your parking lights. Check under your hood on the left side for a connector going into the fender that looks like thisJust noticed it does work using the first position of the light knob. It dosen't work in the Auto position like i thought it would.
I tried to take a picture of it but i have the 2.0 and there is a relay box in the way on the driver side.
have you had any luck getting them to work in the auto position?I tried to take a picture of it but i have the 2.0 and there is a relay box in the way on the driver side.
They are not on during the day with the switch in auto but come on when the headlights turn on.have you had any luck getting them to work in the auto position?
Same hereThey are not on during the day with the switch in auto but come on when the headlights turn on.
im in the same boat I'm thinking that the AD6 (LED Lighting Group) sales code needs to be added which isn't actually in the sales codes to be added and i also think that if get the sales code LPY (Daytime Running Lamp LED Accents) then the fender lights with work properly i have to talk to my area engineer about getting this done.I went to 2 dealers here and they turned everything on to LED they could, and still no luck. Tazer fixed it.
PLEASE update me with any progress you make on this! PM me when you get the fix so i can relay it to my dealer.im in the same boat I'm thinking that the AD6 (LED Lighting Group) sales code needs to be added which isn't actually in the sales codes to be added and i also think that if get the sales code LPY (Daytime Running Lamp LED Accents) then the fender lights with work properly i have to talk to my area engineer about getting this done.
Negative. LPY doesn't work.im in the same boat I'm thinking that the AD6 (LED Lighting Group) sales code needs to be added which isn't actually in the sales codes to be added and i also think that if get the sales code LPY (Daytime Running Lamp LED Accents) then the fender lights with work properly i have to talk to my area engineer about getting this done.
