LatteSipper
- Jan 5, 2021
- Massachusetts
- '21 JLU Sahara 6MT, '23 Highlander
Got it...LC6 may require the resistor approach. Thank you!As long as you're OK with the Resistor approach (if needed) the LC6i should work.
It's unknown (to me) if the resistance the Uconnect system will see from the Audio Control LOC will be sufficient to trick the load sensing test. For that reason, if you decide to try it, just make sure you have the resistors in hand in case you need them (they're cheap).
