IPvFletch
AFAIK you can't do that w/out an LOC.I did play with my gain and the amp still cuts out when its turned all the way down so maybe it is the signal coming in. The Kicker LOC I am using is very low tech, you are basically connecting RCA connectors to the speaker line. I have used this set up in other cars but it might not be adequate with the newer more advanced Uconnect. I will order the LC2i and let you know if that solves all my problems.
Thanks a lot for the help!!!!!!!![]()
Or use the high-level inputs on your amp direct from the OEM speaker wires.
