Accidentally yanked a plug on transfer case. Need help!
Sportacus
Stephan
Empire
Wrangler JLU
So we got my transfer case out and were starting to install the rubi one when it rolled off the transmission jack and the plug got yanked out.
anyone know how i can fix this
Jeep Wrangler JL Accidentally yanked a plug on transfer case. Need help! IMG_8047
Jeep Wrangler JL Accidentally yanked a plug on transfer case. Need help! IMG_8046
Jeep Wrangler JL Accidentally yanked a plug on transfer case. Need help! IMG_8048
Terrymo
Terry
2023 JLURXR 3.6 ET
Ok many wild ass guesses to follow.
Can you show the other end (face) of the connector. Many of these connectors take a two prong depinning tool. I depinned a turn signal connector by using a paper clip with a very small bend in the tip.
You may find the connector with short leads here
https://connectorexperts.com/i-24626072-transfer-indicator-switch-4wd-position.html
Last long shot…it looks similar to the horn connector if you need to salvage and splice something.
That’s all the nonhelpful guesses I have
Atomic-Mouse
Northeast
Terrymo
Terry
2023 JLURXR 3.6 ET
If you are able to repair it I would be curious to know how you depinned the wires from the connector.
dmaxw
Don
Oregon
2021 Jeep Wrangler Rubicon
Looks like same connector as one I had to repair on daughter’s rig. The center should pop out of the shell, likely pressing in the small tabs on the side that lock into the square holes. I was able to keep the pins and just solder the wires back to the pins. Make sure to push the needed wires into the back of the shell first tho, or you’ll have to undo the repair and get it right. Possibly speaking from experience…
Sportacus
Sportacus
Stephan
Empire
Wrangler JLU
I dropped it off at @roaniecowpony house last night so he could work on repairing it. He sent me this image last night.
He also found a cheap $15 ebay version if the repair doesnt work. And then theres the final boss mopar version for $60 plus tax (if even available).
Jeep Wrangler JL Accidentally yanked a plug on transfer case. Need help! 2027559994354310313
Terrymo
Terry
2023 JLURXR 3.6 ET
Cool. @roaniecowpony whats your depinning tool/method?
roaniecowpony
Retired Engineer
I've fought worse connectors. The puzzle of connectors is figuring out how they come apart. This one locks the pins in with that white insert. Then you can access the lock tabs, which in this connector are part of the main body of the connector. The lock insert on this connector is misleading in that some connectors with a face inserted lock also extract the pin out of the face side. These pins go in and out of the back.
Jeep Wrangler JL Accidentally yanked a plug on transfer case. Need help! 1b700e7f-be35-4bd2-af9a-30cd56edb272
roaniecowpony
Retired Engineer
These connector pins are removed like the very first connector he depins in this video (after removing the white plastic lock in the face side).
roaniecowpony
Retired Engineer
Jeep Wrangler JL Accidentally yanked a plug on transfer case. Need help! work for beers
This keeps my enormous income below the tax radar. My preferred payment is Modelo Negra, or PBR if that's not available, or just about any swill in a pinch. But, if a Georges LaTour Cab is offered, I generally don' t turn that down.
SadRobot
Los Angeles
2025 Prius LE
So in keeping the tally @Sportacus owes you 1 case of Modelo for fixing the connector and 1 order of french fries for me for picking up the connector and driving it to his house. 🤣
