A/T Tire Question
happy ending tho as on this set of tires I got the hazard warranty as Discount tires sold me 5 certificates for the price of 2 so I decided to do it and lo and behold it paid off :)..they replaced it no hassle at all.
Jeep Wrangler JL A/T Tire Question {filename}
The Last Cowboy
San Antonio, TX
2020 JL Willys 2 door
Yes, slightly larger tire
Your Sport S came with 255/75R17 tires, 32.2” tall. I would suggest 285/70R17 at 32.8” tall, as your slightly larger option. The height difference will add about 1/4” to your stance. They will fit with no further need to modify the Jeep.
Mine for perspective. It came with 255/75/17s. The tires shown are 285/70R17C Toyo Open Country RT Trails. More aggressive and noisy than you would probably want. But like a luxury ride compared to the Firestone MTs that is came with.
Pardon the shiny tires. This was the day they were installed. I would never do that on purpose. :LOL:
Jeep Wrangler JL A/T Tire Question IMG_2282
Jeep Wrangler JL A/T Tire Question IMG_2311
CapeArt
CapeArt
BB
Cape Cod
2023 JL Sport S, Porsche 987S, MazdaSpeed Miata
My Sport S OEM is 245/75R17
The Last Cowboy
San Antonio, TX
Okay, then a 255/75R17 will fit for a slightly larger tire, and the size on mine will fit too. The OEM wheel widths are the same between yours and mine. So now you have two options as far as a size increase. Your current tires when new were about 31.6" tall. Different manufacturers will have slightly different specs.
WrangleredUp
New Jersey
‘25 JLUW XR (Joose)
I would highly recommend trying to find a set of Rubicon take off wheels and tires here on the forum. There are some great deals out there. BFG Ko2 33s should fit nicely with your setup. I have stock Ko2 35s on my rig, and they’re super quiet and have great on-road manners. Just make sure to dial in your PSI.
2nd 392
Ca
☝ At least the tires, many like me upgrade to 35’s and all but give away the almost like new 285/70’s. …. $100 apiece at 16 months with low miles. If new I would prefer the also light Toyo AT3, but for the price of pull offs the KO2’s would be just dandy.
There’sOnlyOne
Greg
NW Georgia
2021 JLUR
Michelin makes an AT in the LTX Defender. the edge is little more "aggressive" otherwise it looks like a typical defender. I had a set on a 2001 F250 4x4 CCSB 7.3 from 2012 to 2022. Put 35k miles on them, all street. no issues, looked new and very little tread wear. ride was typical Michelin defender ltx. i have a 2011 Pilot that has been driven over 200K miles and except for one time (wont do that again) i have always had the Michelin ltx defenders. easily do 70K and only replace because at that mileage they do become "hard" on the ride but the tread depth is still 2-3 '32nds away from replace wear depth.
they also make a LTX Trail. Discount Tire can order either of those. Michelin defenders are excellent tires and i definitely understand your liking of them. so if you want to stay with the very well made Michelin line check these out.
gato
New England
2021 JLUR
well sometimes ya got to worry....my first sidewall tear ever...
I was referring to the OP's use case - driving on the beach.
He did mention his concern about sidewalls and rocks. "... but the beach I most frequent is rocky, especially in winter, and I have a concern with the Michelin sidewalls on this terrain, so I am interested in a A/T that is good on sand, wet roads, and quiet on highway – and better in the snow than LTX"
LT tires specifically have higher strength sidewalls (to support load), and off-road LT tires from some makes are thicker sidewall rubber and offer more plies in the sidewall than others. Specifically, I'm referring to the Cooper and Mickey Thompson LT off-road line of tires.
azwjowner
Phoenix
Something like a 255/75/17 Nitto Terra Grappler in C load would also be good. A highway-like tread but a bit tougher.
TARHEELKIDD
Greg
Stockbridge, Ga
2020 Jeep Gladiator,1993 Jeep Wrangler,1967 Camaro
To further confuse you check out Toyo AT3. I prefer them to the KO2’s they replaced, better wet/mud and nowhere near the rock magnets. They rate highly and are also light for size as apposed to heavy Falkens and Nittos. The ~9 lbs less weight is why I chose them over the MTBB. On balance a terrific tire and pleased with them. No snow but others have reported good performance.
Same here for this exact reason. I have 37x13.5x17 and I am very happy I changed to the Toyo AT3. The 9 LBS difference is noticeable while driving.
There’sOnlyOne
Greg
NW Georgia
2021 JLUR
Bridgstone makes a few Dueler AT. I know their Dueler street versions like a Michelin Defender is as good a tire. I know a few that have easily driven 80k on a set.
yokramer
Snark Incarnate
Generally going 80k miles on a set of tires isnt something that lends itself to a good performing off road tire.
There’sOnlyOne
Greg
NW Georgia
2021 JLUR
Of course not. I was referring to the street versions. But an AT that would reliably make it to 80k would be nice. That's not happening though. The OP has interest in a Michelin but wants some AT also so that's why I mention the Michelin and Bridgestone versions.
FLTrailRider
2021 Rubicon 2dr
I have run the Nitto Terra Grappler's for years a great tire.. but I noticed that lately that
milestar patagonia x/t are available now at walmart now for way less $$ and look to be just as good. Like 3/4 to 1/2 the price.
Not as much side wall, but they are great tires.
