5.7 hemi swap
salmanj
Salman
Bahrain
2021 Jeep JL
so I have been looking around for a while but I'm not getting enough information on this topic. Im looking forward to doing a 5.7 swap in my 3.6 Jeep JL Sahara, and I'm wondering what parts would have to be changed (transmission, axles, etc) and I was also wondering how much it would cost.
Grayone
SE Mn
2022 TRX, 392 Rubicon (sold), 2 door Rubicon
As the old saying goes, " If you have to ask the cost, you can't afford it..." Seriously, having it professionally done, close to 30k give or take.
autotragic
the cornbelt
'21 JLR 6MT
To be fair a lot of that 30k is the brand new crate motor they want to drop in it. If you're dropping a junkyard motor in it maybe freshened up a little bit and willing to do the labor yourself it is significantly cheaper.
jellis4148
Missouri
2019 Jeep Wrangler JLU Rubicon
Engine, Transmission. Probably front/rear diffs, cause I doubt the stock ones will last long. I'd say all in about $70,000 if you do all new.
autotragic
the cornbelt
'21 JLR 6MT
The transmissions fine unless it's a manual. The front axle probably isn't the best but it'll work fine at least for a while. That's entirely up to how he drives.
swampflyer
rick
florida
retired
Electronics will be the bummer.
autotragic
the cornbelt
'21 JLR 6MT
Not really. What is a pain is getting the old harnesses out and putting the new ones in to support the V8. Obviously a harness meant to run six injectors and six coil packs isn't going to work on the V8 hemi. But everything else will be fine. The stock Jeep electronics are capable of handling the V8 with a reflash.
Powelligator
Parker, CO
2006 LJ Rubicon, 2022 JL Rubicon
If you can find a wrecked 392 then you have a wiring harness, drivetrain, etc. Just replace what's damaged. You could possibly even re-use the computer.
Mudduck
Jay
Michigan
2021 Willys 4door
And here I was fretting over the cost of finishing up a rotary swap on my Samurai.
Mudduck
Jay
Michigan
2021 Willys 4door
If you do start this, please make a thread. would like to see the progress
Punkn89
Alex
Maryland
2019 Wrangler
Probably better off buying a 392. More power and you’ll probably spend less money. There are used ones around 70k.
stumblinhorse
Everything you need to know…
https://www.dakota-customs.com/installs
Shibadog
Bowling Green, Ky
2020 Wrangler Sport S hardtop
Way back when a local speed shop had a sign over the counter “Speed costs money. How fast you wanna go?” Still applies?
Traveller128
Robert
Oasis Idaho
2022 Willys 2 Door 6 speed
Volvo Master Technician
Brand new 5.7 crate, found them last month for $5995. The lion's share is NOT the hemi. Throttle body to oil pan, injectors, exhaust manifolds.
