GrayWolf.Overland
- Subash
- Sep 9, 2021
- Maple Ridge, BC, Canada
- Website
- www.instagram.com
- 2025 JLU Rubicon (Anvil Gray)
- Build Thread
- Link
- Vehicle Showcase
- 2
Once you have learned to adapt your driving to the 4xe drivetrain, it is a hoooot. I had a 3.6 v6 JLU before my current 4xe so I will give you these points that are relevant to someone moving to a 4xe
37s, 2.5 lift, tires tucked in and street legal on all grounds.
- 4xe is a better commuter jeep. You will find an urge to keep it street local as much as possible as it gives you 42kms on electric-only per full charge - which is plenty for around town commutes, school pickups and grocery runs.
- When off-road, you need to learn to use the modes (electric, hybrid, e-save) based on the type of off-roading you do. If you need the most control - use e-save + put the shifter on manual when you are doing slow rock crawls and technical sections that require finesse/control. In washboards and fire roads, kick in on electric or hybrid and cruise along in silence.
- Use max-regen on every scenario other than long highway drives. You will learn to optimize coasting, braking and harvest the most out of regenerative braking once you get the hang of it.
- Get next to the hot rod cars on stop light and smoke them (4hi-auto and e-save -> uses all the torque and hp without throttling)
