4x4 shift issue
Glovetown
Darren
St Albert,Ab
2021 wrangler
Hey,
2021 sport S 2 door grinding/whine
Noise when shifting from 4h (in snow)
To 2H. It happened a couple times this week. Also it’s -38c in Alberta as well. Any thoughts?
Renegade
Zac
Signal Mountain, TN
‘20 JT
There's a lot going on when you go into and out of 4H at speed. Your front inner passenger axle shaft actually changes directions due to the FAD disconnecting, and the driveshaft starting/stopping spinning. It may actually take a little time for your FAD to disconnect the coupler, even when the transfer case is no longer engaged. Does it return to normal after a short period?
Glovetown
Glovetown
Darren
St Albert,Ab
2021 wrangler
Yes about 30 seconds after the noise
Shibadog
Bowling Green, Ky
2020 Wrangler Sport S hardtop
As noted a lot going on. The cold may play a role as well. Mines pretty smooth on the 4H to 2H shift at moderate speed.
Glovetown
Glovetown
Darren
St Albert,Ab
2021 wrangler
How is yours doing 2H to 4h?
mine is a little stiff
