4 low after regear
damageinc321
Indiana
2018 wrangler rubicon unlimited
I have an 18 Rubicon 3.6 auto jlu with 38s and I regeared to 5.13s. The shifts in 2 wheel and 4 high feels good but 4 low seems to shift funny when wheeling. I don't have much experience with 4 low because I never really used it before but now I'm hitting obstacles where 4 low world be better but I'm a little hesitant because it feels like it's really shifting hard. Any insight would be great maybe I'm just not used to it just want some input. Thanks.
GATORB8
CLT NC
21 JLURe, 06 LJ, 25 HDZR2
Rolling it in neutral at a couple MPH during shifting helps.
damageinc321
Indiana
Not what I meant, it goes into 4 low fine. I'm referring to shifting from 1st to 2nd to 3rd and so on. It hard shifts and feels like it holds gears too long maybe.
GATORB8
CLT NC
Oh, 10-4. Same for us.
I only use it in Auto for speed. Obstacles M 1 or 2, Trail Riding M 3-5
Vinman
Vince
Calgary, Alberta
2021 JLU Rubicon
You’re just feeling the lower gear ratio now, completely normal to have a bit more aggressive shifting in 4 low.
grimmjeeper
Roy
Castle Rock, CO
www.grimmjeeper.com
enginerd
4 low changes the shift points in the transmission. You'll get used to it.
AcesandEights
Aces
So. Oregon
2024 Toyota 4Runner
Yeah, it's just how it works. You're multiplying the torque by four in four-low, so it's got an incredible amount of torque in comparison to two-wheel or four-wheel "high". Re-gearing increased the torque by another 25%, more or less,
6.2Blazer
Ohio
2019 JL Sport
It's normal for automatics to feel quite a bit different when in 4 low. The main reason is simply the torque multiplication of the 4 low gearing. 4 low on a non-Rubicon is almost 3 times lower overall gearing and a Rubicon it's typically 4 times. Plus on newer vehicles the ECU usually changes the shifting characteristics on top of that. If it shifts fine in 2 or 4 high I would fully expect how it's shifting in 4 low to be "normal".
On a side note when actually off-road on a trail (more than just wet grass or a snow covered road) I spend more time in 4 low. Any continuous slow speed driving over rough terrain or obstacles is just easier on the trans in low range.
