99mhz
- John
- May 13, 2018
- Maple Valley, Washington
- 2018 JL Rubicon 2 door Mojito!
- Vehicle Showcase
- 1
@gts and @rustyshakelford thanks for the help. Disconnecting full power did it. I disconnected the two negative leads on the main battery and separated them. for good measure I put a multi-meter on the battery + and fender ground and watched as some large capacitor discharged. I waited till it got down to about 1/2 volt then reconnected everything.Thanks I'll give this a try tonight. I took the whole negative terminal off, but both grounds still tied together, and still had power in the dash!
Took it down the highway and did the 6th gear relearn procedure, and the ESS errors are gone! Woot! I'm going to find a dirt road in the morning to test if that solved my "service 4x4 system" issue too
