Need to recalibrate/flash computer after regearing?
WildCatguy
Luis
Tucson, AZ
2018 Jeep Wrangler Sport
You should have bought a Rubicon, or maybe your dealer will give you a fair trade out.
Just changing gears so I can get my 6th gear back on the highway.
MartyP
Marty
NorCal
2019 JL 2door
You don't need a flash or programmer to recal if you have a MT. I have a 2019 JL/MT and was getting ESS errors on the dash after I swapped the stock axles (3:45) for Ribicon axles (4:10). I followed the attached procedure (can't remember which post I got this from, sorry) and the Jeep reprogrammed itself! Basically, disconnect the negative terminal on both batteries, wait 30 sec or so, then reconnect. Drive the Jeep at a constant speed in 6th gear (50-55 mph) and hold it there for at least 30 seconds. That's it. Worked for me.
wrangster
Ray
Sold the JLUS, New Ford Ranger 4X4 Lariat
Retired and happy!
I still have 8 on flat highway, otherwise 7 is still strong using 275/65/18s on a sport pentstar 6. The tires are light XL load rating Nitto Terra grapplers. After these wear out going to 265/65/18s to get my ride back! my daily driver.
rizion
Caleb
Houston
Wrangler JL 2dr Sport S
Jeep Wrangler JL Need to recalibrate/flash computer after regearing? recal.JPG
Do I have to disconnect the aux battery at its terminal or just at the main battery? Looks like both are ran to the main battery connection
Chupacabra
Greenville, SC
2021 JLU
You may not need to program anything with a manual. Buddy has a JK and went to 4.xx gears and the speed sensor on the JK is on a front wheel, not the transmission. So there's no need to reprogram on the JK at least. I wouldn't be surprised if JL is the same.
word302
Oregon
JLU
That procedure isn’t going to properly adjust your speedometer for the new gears. You definitely need a flash/programmer.
Chupacabra
Greenville, SC
2021 JLU
Pretty sure the speed sensor on the JK/JL is not tied to the transmission or driveshaft. It's on one of the wheels, hence no speedometer issues with new gears. If it's a manual, then there's no transmission issues either.
