4 aux buttons
Sarsquid71
Derek
Virginia
2024 Wrangler Willys
I just bought a 2024 Wrangler Willy’s and can’t figure out where to hook up anything directly controlled by the 4 aux buttons. Any suggestions?
GATORB8
CLT NC
21 JLURe, 06 LJ, 25 HDZR2
Two options, one is by the battery under hood, the other is in the passenger footwell. Footwell also has IGN+ and B+ available. 1 and 2 are 40 amp relayed, 3 and 4 are 15 amp relayed.
IIRC they are taped up, look for a wire run that just ends.
tomk62
Tom
South Carolina
2024 JLU Sahara Anvil, 2019 Cherokee
I believe there pigtails both behind the glove box and in the engine bay near the battery. You should be able to find many youtube vids on how to hookup.
GMONEY
Greg
Temecula California
23 2D Rubi Earl
If you have the installed aux buttons from the factory there are leads on the passenger side up behind the glove box and some in the engine compartment down by the battery.
Pretty sure there is something in the manual if nit youtubs has plenty of vids.
THAW
Foster
23 JL4DrRubicon
Also, IGN+ and B+ are 10A
Deleted Member RoadNomad
Guest
One of the hot setups to use the Aux switches for are a winch.
Instead of having your winch powered hot all the time put a solenoid under the hood controlled by an aux switch and feed directly from the battery, this way you don't have to worry about a front end collision with a hot winch.
Plus if you get stuck in the mud you don't have to try to get under the vehicle to manually switch power on the winch. Easy and useful both!
doc73
Pat
Chester County PA
2024 Rubicon JLU
Link above was wrong for my 2024 rubi. See the watched updated pic for the colors (which was correct as I wired a dash cam to day on one of the aux switches).
Jeep Wrangler JL 4 aux buttons 1000009360
THAW
Foster
23 JL4DrRubicon
I was also misled by the 2018 picture at the start of that thread. The image does clearly state 2018, but it'd be nice if the post were updated to mention the wiring color scheme has changed.
