4.88 or 5.13?
DesertsJL
DesertsJL
JLUR
Debating between 4.88s and 5.13s in a 3.6 auto with 37's. Sounds like people have done both and are happy. Is there a right answer? If i've never driven a stock JLUR on 4.10's, is 5.13 going to be a huge jump?
Go with the 5.13. You won’t be disappointed. There really is only a 5% difference between the two. Your 8th gear is super tall and you won’t feel high strung at all on the freeway.
I ended up installing 5.38’s and I’m currently running 37” BFG’s.
Deleted member 33002
Guest
Can anyone tell me 70mph RPM with 4.88 & 5.13 3.6L with 8speed?
Halstem1
Alaska
I can't tell you the RPM on 4.88 but I found a trick on 5.13. I was playing with the gearing calculator and realized the final gear ratio on 4.10 in 7th gear is identical to the 5.13 in 8th gear on the 3.6 auto. Both have a final gear ratio of 3.44. This assumes all else stays the same after re-gear. So I set the cruse at 70 and 75 mph and manually put it in 7th. That would be my new 8th. If the RPM's are higher than you want, then go 4.88. I was able to get up to 79 mph and 2600 rpm in 7th which felt perfect. And actually where my jeep would be even if I didn't manually put in 7th. I shift into 8th a lot now but any wind or hills will downshift to 7th. I'm not sure I've ever cruised above 80 mph.
kobejo34
Stephen
Hoschton, Ga
19 JLUR
Do you feel like your power is too low so you manually put in 7th? wouldnt it drop to 7th if you needed to pass? Thank you for your answer as I'm debating the two gears as well.
Halstem1
Alaska
I only put in 7th manually with my stock gears to have a feeling where the RPMs would be when I re-gear. I was debating between 4.88 and 5.13. Everyone recommends the 5.13 with 37s but I was afraid the RPM would be too high on the interstate. To see if it was, I manually put it in 7th which would be my new 8th. I drove that way for about 30 minutes. RPMs were not screaming at 2400-2600. I had plenty of power. Now with it in manual, I don't know what the auto will do with 5.13s. At 2400 RPMs I can't imagine it will downshift a lot. I'm sure if you punch it, it will drop to 5th or 6th. But I had plenty of power in that rpm range.
With my 4.10s now, it downshifts a lot. bounces between 8th and 7th constantly. Like you said, power wise in the 4.10 it will drop to 7th on its own. I was only doing to determine if 5.13 was too low for the highway at 75 mph.
Around town shouldn't matter. The auto will pick the gear it wants for the ideal rpm.
Halstem1
Alaska
Found this chart last night on the JT forums. Now I’m more worried about pinion size 4.88 vs 5.13 leaning towards 4.88 since it should work with 38’s and slightly bigger pinion size also is a plus.
Jeep Wrangler JL 4.88 or 5.13? 2EB4F08D-7194-42E4-99CE-3F8DB9B171D6
I've seen pinion size debated on here and on there. Every single shop or person I've talked to says its not significant enough to base your decision on. Local shops, northridge, JK Gear on YouTube, I think Yukon talks about it... Supposedly what matters is the surface area of the tooth and not the actual pinion size. Just what I've been told by actual people that install them regularly. FWIW
Guest
True!
2Wheel-Lee
Lee
Orange County, CA
2020 JLUR, 2006 Dodge Ram 2500 CTD, 1986 Suzuki Samurai, 1975 Datsun 620
Exactly! The difference is so little. The margin of failure between 4.88 and 5.13 is so small that if something were to damage the 5.13 pinion, it would likely damage the 4.88 pinion (or ring gear). Anyone who damage the 5.13 gears would have likely damaged 4.88 gears.
If I damage my 5.13 gears, I'll probably need to go with Dana 60s, anyway.
Rodeoflyer
Bert
Conifer, Colorado
I can't wait to go to 5.13 gears. I can already get out and walk next to the Jeep with the 6 speed in 4lo with 4.10's. 5.13's will be insane crawling ability.
2Wheel-Lee
Lee
Orange County, CA
Even though I like the 5.13 gears, sometimes I even wish I had deeper gearing - even with the 4.1 transfer case. I guess that's where the Atlas transfer case would come in...if I really needed it. But I don't.
Rodeoflyer
Bert
Conifer, Colorado
God an Atlas would be incredible.
IronScott
NW Arkansas
2019 JLU Sahara, 1992 Jeep YJ, 2002 Chevy Silverado
Ha ha. So much for good decisions. I just ordered a UD44 with 4.88 and will re-gear the rear to match. I'm running 37s on a Sahara with the 2.0L, so even 4.88 is a huge jump. I hemmed and hawed over it. Oh, well. I doubt I'll regret it but can always change in the future if not happy.
Halstem1
Alaska
haha. Good decisions are dumb. oh man. that's awesome. I'm jealous. Is the UD44 plug and play with the locker? or do you have to do more? I bet you'll like the 4.88. Local shop told me you can't go wrong either way. Especially from the 3.43 or whatever is in the sahara. I really don't hate my 4.10 with 37's which is why I think 4.88 might not be horrible at all.
However... UD44... I'd end up on 39" KM3s i'm afraid.
IronScott
NW Arkansas
I think my wife would hurt me if I went even taller, though she does like the ride of the 37s. The UD44 is plug and play, supposedly. I'm just going to use one of my Aux switches since I don't have the factory locker switches, plus I won't have the rear locked yet anyway.
I'm hoping aftermarket e-lockers or Truetrac are available in the next year or so but I'm not holding my breath. I don't mind going with ARB but would rather not.
