392 Suspension
AmericanPatriot100
AmericanPatriot100
Kitsap Co
2025 Wrangler Sport JL
Yeah! I’m super stoked! I was super stoked to be paying $100! And then I went to pay him and he’s like nah keep it. Just look at it like you’re helping me clear out my storage. That said I’ll have some take off rubicon suspension I’m happy to gift to someone and a set of JTR shocks with the wrangler spacers.
AmericanPatriot100
AmericanPatriot100
Kitsap Co
Anyone know the length of the M10 button top or M8 13mm hex bolts that go with the mopar tailgate reinforcement? I guess when they installed the guys teraflex tire carrier they reused those bolts.
Aonarch
Mike Hawk
North GA / MT
'25 JLUR '41, '24 F-150 V8 4x4, '22 Mach 1 6MT
Motorsports Engineer
I'd look through some instruction manuals, or part lists for the Mopar one, or aftermarket. Start with Mopar.
AmericanPatriot100
AmericanPatriot100
Kitsap Co
I did that and asked chat gpt. Apparently mopar doesn’t disclose the length of those bolts. But it did say they’re ~60mm long. So I’m hoping they’re M10x1.5x60. When I got my relocation bracket a few months ago I had to buy some bolts for it to mount the tire carrier. I’ll probably call or stop by the dealership and see if the parts department can look up the specs.
Take your caliper and measure the thickness of the parts being clamped. With the carrier removed, measure the depth of the threaded hole in the tailgate. Add the two and get the bolt grip length (not overall length).
AmericanPatriot100
AmericanPatriot100
Kitsap Co
Thank you for your help. I think I got the correct bolts I need because of your smartness! Too bad they’re not black bolts to match my jeep but I do have the black paint I can use to match them! I’ll post photos when I’m done!
You never know on the internet if someone knows how a bolt is measured of if they can use a caliper or even if they know what one is. For all I know, you're a full blown prototype machinist or never saw a steel rule.
AmericanPatriot100
AmericanPatriot100
Kitsap Co
Haha right! I actually have a caliper because I needed precise measurements for my RC cars shocks! My measurements came out to about 53mm. I just mathed in my head when I measured. So I got the 60mm bolts and with the washers should get me to just about even. I’m just a dumb truck driver! My dad was an engineer at McDonald Douglas turned Commercial driver. So I learned to use micrometers and calipers at a young age. Didn’t get his smarts though.
I worked at McDonnell Douglas in Long Beach CA before it was absorbed by Boeing. It's possible I worked with your dad. Careful with those bolts, be sure they don't bottom out in the hole before they tighten the tire carrier. Generalizing, you want a minimum of 1.5 times the bolt diameter of thread engagement. For aluminum, 2 times the bolt diameter of thread engagement is more accepted practice.
AmericanPatriot100
AmericanPatriot100
Kitsap Co
That’s crazy! That’s where he worked! We lived like 3 minutes down the road! He was one of the many layoffs from that location! And one of his best friends/cowowrkers got to stay on because he was a project manager. I still have his aluminum clipboard that all you guys signed!
Zandcwhite
Zach
Patterson, ca
2019 jlur
Hard ride.
4 door, heavy engine, springs will have a high spring rate. But, yes, it will lift it. Nothing a kidney belt and a mouth guard can't fix.
Every lift spring has a higher rate than the stock springs. Sure the 392 springs have a higher rate than 2dr sport springs, but I'd bet they are still lower rate than any aftermarket 2" lift spring. I haven't run 392 springs on anything, but even the xr springs were too soft and wallowy in my opinion. I've yet to see anyone swap stock springs of any kind on to their 2dr and complain they were too stiff.
