35 inch and trans zf8
Dan1419
Daniel
Montreal
Sahara 2019
Hi, I have a jlu sahara and I installed 35 inches and the 8 doesn't fit I know I'll have to change my ratio. My question is what will it wear out my transmission? The question is for those who drive like that right now. Thanks
jludave
The Isle of Long
IT Manager
I assume you mean you aren't seeing 8th gear?
Have you done anything (Tazer, JSCAN, etc.) to update the vehicle's tire size? That's the first thing you should do after putting on larger tires.
TheRaven
Reading, Pennsylvania
Sold
Yeah you need to update the computer so it knows the correct tire size, or your shifting will be all out of whack. Also, what tires did you put on?
I'm running 35's on my 80th (essentially a Sahara) and I still see 8th gear regularly...but I did update the tire size in the computer and I also made sure I didn't buy really heavy tires. That makes a big difference.
tomk62
Tom
South Carolina
2024 JLU Sahara Anvil, 2019 Cherokee
Same here.
Dan1419
Daniel
Montreal
Sahara 2019
Yes, I adjusted the tire size with jscan
Dan1419
Daniel
Montreal
Sahara 2019
Yes i update the cumputer with jscan and my tire is nokian rockproof
jludave
The Isle of Long
IT Manager
So then please explain what the issue is. Are you asking if you need to re-gear?
Dan1419
Daniel
Montreal
Sahara 2019
I wonder if it will break my transmission if I only drive with 7 speeds?
jludave
The Isle of Long
IT Manager
Short answer, no.
But, if you set the tire size correctly you should be able to get 8th gear.
If the tire size is correct and you struggle to see 8th, then you should consider a re-gear.
Dan1419
Daniel
Montreal
Sahara 2019
Short answer, no.
I will change the ratio of my differential more during next winter but I was wondering if I can drive my jeep without breaking my transmission this summer even if the 8-speed does not embark? Is it clearer?
jludave
The Isle of Long
IT Manager
I just answered no in my post above.
Jeep Wrangler JL 35 inch and trans zf8 1710526628298-o2
TheRaven
Sold
Yeah those are heavy...you may very well see 8th gear a lot less, especially if you drive aggressively. You don't need 8th gear for anything but fuel mileage, so it's only really a problem if you decide it's a problem.
Stuckinthesand
CJ
NJ
2019 Wrangler Sport S
In essence 7th and 8th gears are overdrive gears. Do you need to regear? No. I have heavy 35's and wheels on my 19 sport s and I wheel regularly as well as it being my daily driver. I still see 8th if I stay below 72 mph. Anything above that it will stay in 7th. You aren't going to gain anything significant back in terms of gas mileage. I just did a trans fluid change on mine about 12k miles ago and the fluid looked good and nothing out of the ordinary was on the magnets. Keep up on the regular maintenance and you'll be fine.
Oncorhynchus
Moishe
San Jose, CA
2018 JLU Sahara Sting Gray 3.6L
My Sahara with the factory 3.45 gear ratio and 35x12.5R17 (110 lbs wheel +tire) and Jscan, only reaches 8th gear on flat highways. Have driven 34k miles like that and have seen no issues yet. Admittedly you may be worrying about even longer term wear issues than my 34k miles of history so take this one data point for what it’s worth.
