ArcadeTracks
PJ
Pittsburgh, PA, USA
Clearly that was all just unfounded fears.
That's another (small, but they add up) time thing -- using a tool at all. Getting out the ratchet, attaching the bit, disassembling and replacing it after the process.
Wraif
Kevin
New Jersey
19 2-door manual Rubicon, 09 JKU, 23 JT Overland
I found it to be a more after the fact problem. I rolled my 13 JK and in helping my family and I get out, as soon as they opened my door it fell and was dangling by just the door limiting strap and the electrical wires. So now I keep the bolts in on the bottom of the hinges.
yokramer
Snark Incarnate
So when you opened the door it fell away and gave a bigger opening ... seems like a win to me.
etoften
Eric
Washington NC
2021 JLU Willys
He didn't say away. It could have fallen in. I assure you it will fit in the opening. Fact for the day. That's why manhole covers are round. A circle is the only object that won't fall in on themselves.
Wraif
Kevin
New Jersey
Nope, not a win. I sat there, hung there ?, trying to get the wire to not break. I couldn’t get the connection to disconnect. Thinking that I was still gonna save my Jeep.
Jeep Wrangler JL 2026 Door Hinges (Quick Release) - photo IMG_3554
WXman
Central Kentucky
So what, specifically, is different about this vs. just leaving the T40 screws out on a 18-25?
Wraif
Kevin
New Jersey
Lesson learned, the hard way.
Only-In-A-Jeep
North Georgia Mountains
2021 Jeep Wrangler Sport
Reading this article
https://moparinsiders.com/2026-jeep-wrangler-heritage-horsepower-and-trail-ready-innovation/
and the following paragraph caught my attention:
The new hinge design uses revised alignment pins and a self-centering mechanism that helps guide the door perfectly into position during removal and reinstallation — eliminating the need for guesswork or multiple adjustments. Jeep also switched to lightweight, high-strength aluminum hinge components, reducing overall door weight and making it easier for one person to remove the doors without assistance.
So...they are aluminum finally. Wouldn't that solve the hinge corrosion issue? Could we replace the existing hinges with these to prevent corrosion from happening??
Only-In-A-Jeep
We can only hope they've attempted to try to mitigate some of the galvanic corrosion issues while thinking about the hinges.
Check out the linked article and the highlighted paragraph in post 55 of this thread.
WXman
Central Kentucky
So I guess to retrofit a '25 you'd need to buy new hinges and a new door stop rod for all 4 doors. That'll probably get pricey.
Only-In-A-Jeep
But might be worth it if you knew it would prevent corrosion...and honestly, Stellantis should foot the bill.
m3reno
Sal
caldwell
2022 Jeep Wrangler JLU
Hopefully the aluminum is very thick. I had a dirt bike carrier made of aluminum 5/16 square tubing seemed very robust. Coming back from PA from a ride I noticed a little movement and decided to get off at a rest stop. Not a second after I turned in the bike tipped over and came off the carrier. Root cause was stress at the attachment point, it sheered straight across as if I cut it with a laser.
YBABRAT
VIRGINIA
2019 2 Door Rubicon X Wannabe
None... but it pays well.
If it ain't aiircraft quality, it ain't worth trying to upgrade. Jeep parts are cheap parts IMO.
